- To: David Willmore <davidwillmore@gmail.com>
- Cc: Cado-nfs-discuss@lists.gforge.inria.fr
- Subject: Re: [Cado-nfs-discuss] Restarting linear algebra after running out of storage
- Date: Mon, 09 Dec 2019 20:22:08 +0100
- List-archive: <http://lists.gforge.inria.fr/pipermail/cado-nfs-discuss/>
- List-id: A discussion list for Cado-NFS <cado-nfs-discuss.lists.gforge.inria.fr>
David,
> It's running now. Will this complete the factorization or will I need
> to manually perform any other steps after this?
it will only complete the linear algebra (bwc.pl) step. Then you can
restart the cado-nfs.py command, which should recognize that the
linear algebra is done.
Take-home-message: never start a big factorization in /tmp (which is
the default workdir), always use workdir=/some_large_disk.
Best regards,
Paul
- [Cado-nfs-discuss] Restarting linear algebra after running out of storage, David Willmore, 12/09/2019
- Re: [Cado-nfs-discuss] Restarting linear algebra after running out of storage, Emmanuel Thomé, 12/09/2019
- Re: [Cado-nfs-discuss] Restarting linear algebra after running out of storage, David Willmore, 12/09/2019
- Re: [Cado-nfs-discuss] Restarting linear algebra after running out of storage, paul zimmermann, 12/09/2019
- Re: [Cado-nfs-discuss] Restarting linear algebra after running out of storage, David Willmore, 12/11/2019
