cado-nfs - [Cado-nfs-discuss] Bug report
  • From: Bernardo Boncompagni <bernardo.boncompagni@gmail.com>
  • To: cado-nfs-discuss@lists.gforge.inria.fr
  • Subject: [Cado-nfs-discuss] Bug report
  • Date: Wed, 14 Oct 2020 22:52:42 +0200
  • Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=bernardo.boncompagni@gmail.com; spf=Pass smtp.mailfrom=bernardo.boncompagni@gmail.com; spf=None smtp.helo=postmaster@mail-qk1-f169.google.com
  • Ironport-phdr: 9a23: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
  • List-archive: <http://lists.gforge.inria.fr/pipermail/cado-nfs-discuss/>
  • List-id: A discussion list for Cado-NFS <cado-nfs-discuss.lists.gforge.inria.fr>
Hi all, while factoring the C112 1145063074027333577715575387634140159952540179532347720181468319839131063022310865763671680437175978656489571651 the attached error occurred, with both builds Oct 14 11:35 and Sep 28 11:32 GMT.
I uploaded the files I deemed relevant here, please let me know if you need more.
Thank you for your time,
===== Error follows =====
PID176306 2020-10-14 21:51:59,419 Command:Command: /home/ubuntu/cado-nfs/build/ip-172-31-39-108/sqrt/sqrt -poly nfsdata/c110.poly -prefix nfsdata/c110.dep.gz -dep 0 -t 8 -side0 -side1 -gcd > nfsdata/c110.sqrt.stdout.2 2> nfsdata/c110.sqrt.stderr.2
PID176306 2020-10-14 21:52:37,700 Warning:Command: Process with PID 198078 finished with return code -6
PID176306 2020-10-14 21:52:37,702 Error:Square Root: Program run on server failed with exit code -6
PID176306 2020-10-14 21:52:37,702 Error:Square Root: Command line was: /home/ubuntu/cado-nfs/build/ip-172-31-39-108/sqrt/sqrt -poly nfsdata/c110.poly -prefix nfsdata/c110.dep.gz -dep 0 -t 8 -side0 -side1 -gcd > nfsdata/c110.sqrt.stdout.2 2> nfsdata/c110.sqrt.stderr.2
PID176306 2020-10-14 21:52:37,702 Error:Square Root: Stderr output (last 10 lines only) follow (stored in file nfsdata/c110.sqrt.stderr.2):
PID176306 2020-10-14 21:52:37,702 Error:Square Root:    Alg(5): square root is: 555287643083995264499635032445532219388774606091985323176085691206366910433807483650449454541347080611266564030
PID176306 2020-10-14 21:52:37,703 Error:Square Root:    Alg(5): square root completed at 284.07s (wct 37.56s)
PID176306 2020-10-14 21:52:37,703 Error:Square Root:    Alg(0): maximal sqrt bit-size = 16273947 (100% of target size)
PID176306 2020-10-14 21:52:37,703 Error:Square Root:    Alg(0): square root lifted at 284.09s (wct 37.58s)
PID176306 2020-10-14 21:52:37,703 Error:Square Root:    Alg(0): square root is: 516153508739556589022977937011401702913240008517589239368972163227789864034619173427530095526015988391446136082
PID176306 2020-10-14 21:52:37,703 Error:Square Root:    Alg(0): square root completed at 284.11s (wct 37.65s)
PID176306 2020-10-14 21:52:37,703 Error:Square Root:    Bug: the squares do not agree modulo n!
PID176306 2020-10-14 21:52:37,703 Error:Square Root:    terminate called after throwing an instance of 'std::runtime_error'
PID176306 2020-10-14 21:52:37,703 Error:Square Root:      what():  code BUG() : condition 0 failed at /home/ubuntu/cado-nfs/sqrt/sqrt.cpp:1510
