- From: Bernardo Boncompagni <bernardo.boncompagni@gmail.com>
- To: Paul Zimmermann <Paul.Zimmermann@inria.fr>
- Cc: cado-nfs-discuss@lists.gforge.inria.fr
- Subject: Re: [Cado-nfs-discuss] Bug report
- Date: Thu, 15 Oct 2020 13:00:19 +0200
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=bernardo.boncompagni@gmail.com; spf=Pass smtp.mailfrom=bernardo.boncompagni@gmail.com; spf=None smtp.helo=postmaster@mail-qv1-f42.google.com
- Ironport-phdr: 9a23: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
- List-archive: <http://lists.gforge.inria.fr/pipermail/cado-nfs-discuss/>
- List-id: A discussion list for Cado-NFS <cado-nfs-discuss.lists.gforge.inria.fr>
Thank you for your quick reply. Please note that I indeed included the release in the body of the message:
> with both builds Oct 14 11:35 and Sep 28 11:32 GMT
obtained with the "git log" command, unless I don't understand what information should I include.
On Thu, Oct 15, 2020 at 8:28 AM Paul Zimmermann <Paul.Zimmermann@inria.fr> wrote:
thank you Bernardo for your report. (In general, it is good to include also
the release of cado-nfs used, or the exact git commit used.)
With your files, I can reproduce the issue with dependencies 0 and 1.
However, dependency 2 works:
zimmerma@mure:/tmp/cado$ ~/svn/cado-nfs/build/mure/sqrt/sqrt -poly c110.poly -prefix c110.dep.gz -dep 2 -t 1 -side0 -side1 -gcd
Alg(2): square root completed at 42.02s (wct 26.30s)
16254032875050544527560247991133579424804518417
70447936387834629629002635008176793377690777439436264857134749203
These dependencies fail: 0 1 3 4 9 10 11 12 13 17 18 20 23 24 26
These dependencies don't produce that error: 2 5 6 7 8 14 15 16 19 21 22 25
I was also able to reproduce the problem by running cado-nfs.py on your input
number. We'll investigate.
Paul
- [Cado-nfs-discuss] Bug report, Bernardo Boncompagni, 10/14/2020
- Re: [Cado-nfs-discuss] Bug report, Paul Zimmermann, 10/15/2020
- Re: [Cado-nfs-discuss] Bug report, Bernardo Boncompagni, 10/15/2020
- Re: [Cado-nfs-discuss] Bug report, Emmanuel Thomé, 10/21/2020
- Re: [Cado-nfs-discuss] Bug report, Bernardo Boncompagni, 10/21/2020
