- To: "Thomas D. Dean" <tomdean@wavecable.com>
- Cc: Paul Zimmermann <Paul.Zimmermann@inria.fr>, cado-nfs@inria.fr
- Subject: Re: [cado-nfs] Cado-nfs Failed Factoring 143 digits
- Date: Wed, 13 Apr 2022 23:24:47 -0700
- Authentication-results: mail3-relais-sop.national.inria.fr; dkim=none (message not signed) header.i=none; spf=SoftFail smtp.mailfrom=Emmanuel.Thome@inria.fr; dmarc=fail (p=none dis=none) d=inria.fr
Can you send me the first ~50 lines or so of the file
/tmp/cado.j7xjqm4s/c145.renumber.gz (dezipped, of course).
I changed something with this earlier this week (700809586). If that file
was created earlier than that, you might need to recompute that file
(well, you can edit it by hand as well, but recomputing it should take
only a few minutes).
E.
On Wed, Apr 13, 2022 at 10:43:25PM -0700, Thomas D. Dean wrote:
> On 4/13/22 22:29, Paul Zimmermann wrote:
> > Hi Thomas,
> > > I am attempting to factor a 143 digit number.
> > it seems you are using CADO-NFS 3.0.0. Did you try with the latest git
> > version?
> > Paul
> > git log
> commit 4f80363c707a832f167900efb58cf08000f7c63f (HEAD -> master,
> origin/master, origin/HEAD)
> Merge: 35c7392c1 27b9ef4e2
> Author: Emmanuel Thomé <emmanuel.thome@inria.fr>
> Date: Wed Apr 13 15:45:44 2022 +0000
> Tom Dean
- [cado-nfs] Cado-nfs Failed Factoring 143 digits, Thomas D. Dean, 04/14/2022
- Re: [cado-nfs] Cado-nfs Failed Factoring 143 digits, Paul Zimmermann, 04/14/2022
- Re: [cado-nfs] Cado-nfs Failed Factoring 143 digits, Thomas D. Dean, 04/14/2022
- Re: [cado-nfs] Cado-nfs Failed Factoring 143 digits, Emmanuel Thomé, 04/14/2022
- Re: [cado-nfs] Cado-nfs Failed Factoring 143 digits, Emmanuel Thomé, 04/15/2022
- Re: [cado-nfs] Cado-nfs Failed Factoring 143 digits, Thomas D. Dean, 04/15/2022
- Re: [cado-nfs] Cado-nfs Failed Factoring 143 digits, Thomas D. Dean, 04/16/2022
- Re: [cado-nfs] Cado-nfs Failed Factoring 143 digits, Thomas D. Dean, 04/17/2022
- Re: [cado-nfs] Cado-nfs Failed Factoring 143 digits, Paul Zimmermann, 04/17/2022
