- To: "Thomas D. Dean" <tomdean@wavecable.com>
- Cc: cado-nfs@inria.fr
- Subject: Re: [cado-nfs] Cado-nfs Failed Factoring 143 digits
- Date: Sun, 17 Apr 2022 07:40:47 +0200
- Authentication-results: mail2-relais-roc.national.inria.fr; dkim=none (message not signed) header.i=none; spf=SoftFail smtp.mailfrom=Paul.Zimmermann@inria.fr; spf=None smtp.helo=postmaster@tomate
Hi Tom,
this is strange. Please try to change line 5020 of cadotask.py from:
dep = self.state.get("next_dep", 0)
to:
dep = 34
Or you can run the sqrt command by hand as follows, assuming your computer
has 8 cores:
/usr/local/lib/cado-nfs-3.0.0/sqrt/sqrt -poly /tmp/cado.xqnxt6gq/c125.poly
-prefix /tmp/cado.xqnxt6gq/c125.dep.gz -dep 34 -t 8 -side0 -side1 -gcd
Best regards,
Paul
> Date: Sat, 16 Apr 2022 21:16:14 -0700
> User-Agent: Mozilla/5.0 (X11; Linux x86_64; rv:91.0) Gecko/20100101
> Thunderbird/91.7.0
> From: "Thomas D. Dean" <tomdean@wavecable.com>
> On 4/16/22 10:41, Thomas D. Dean wrote:
> In attempting to factor a 123 digit number, sqrt seems to be looking for
> dep 40 when the deps range from 0 to 33;
> Error:Square Root: Command line was:
> /tmp/cado.xqnxt6gq/c125.poly -prefix /tmp/cado.xqnxt6gq/c125.dep.gz -dep
> 40 -t 8 -side0 -side1 -gcd > /tmp/cado.xqnxt6gq/c125.sqrt.stdout.7 2>
> /tmp/cado.xqnxt6gq/c125.sqrt.stderr.7
> Error:Square Root: Stderr output (last 10 lines only) follow (stored
> in file /tmp/cado.xqnxt6gq/c125.sqrt.stderr.7):
> Error:Square Root:
> /usr/local/lib/cado-nfs-3.0.0/sqrt/sqrt.r4f80363c7+ -poly
> Error:Square Root: Warning: dependency 40 does not exist, reducing
> the number of threads to 0
> Error:Square Root: Error, no more dependency
> Error:Square Root:
> The files range from
> c125.dep.000.gz to c125.dep.033.gz
> c125.dep.side0.000.gz to c125.dep.side0.033.gz
> c125.dep.side1.000.gz to c125.dep.side1.033.gz
> Tom Dean
- Re: [cado-nfs] Cado-nfs Failed Factoring 143 digits, (continued)
- Re: [cado-nfs] Cado-nfs Failed Factoring 143 digits, Thomas D. Dean, 04/14/2022
- Re: [cado-nfs] Cado-nfs Failed Factoring 143 digits, Emmanuel Thomé, 04/14/2022
- Re: [cado-nfs] Cado-nfs Failed Factoring 143 digits, Emmanuel Thomé, 04/15/2022
- Re: [cado-nfs] Cado-nfs Failed Factoring 143 digits, Thomas D. Dean, 04/15/2022
- Re: [cado-nfs] Cado-nfs Failed Factoring 143 digits, Thomas D. Dean, 04/16/2022
- Re: [cado-nfs] Cado-nfs Failed Factoring 143 digits, Thomas D. Dean, 04/17/2022
- Re: [cado-nfs] Cado-nfs Failed Factoring 143 digits, Paul Zimmermann, 04/17/2022
- Re: [cado-nfs] Cado-nfs Failed Factoring 143 digits, Paul Zimmermann, 04/18/2022
- Re: [cado-nfs] Cado-nfs Failed Factoring 143 digits, Thomas D. Dean, 04/18/2022
- Re: [cado-nfs] Cado-nfs Failed Factoring 143 digits, Emmanuel Thomé, 04/17/2022
- Re: [cado-nfs] Cado-nfs Failed Factoring 143 digits, Thomas D. Dean, 04/20/2022
