- To: "Thomas D. Dean" <tomdean@wavecable.com>
- Cc: Paul Zimmermann <Paul.Zimmermann@inria.fr>, cado-nfs@inria.fr
- Subject: Re: [cado-nfs] Cado-nfs Failed Factoring 143 digits
- Date: Wed, 13 Apr 2022 23:55:49 -0700
- Authentication-results: mail2-relais-roc.national.inria.fr; dkim=none (message not signed) header.i=none; spf=SoftFail smtp.mailfrom=Emmanuel.Thome@inria.fr; dmarc=fail (p=none dis=none) d=inria.fr
ok, confirmed.
1 - recompile
2 - grep freerel /tmp/cado.j7xjqm4s/c145.cmd
3 - re-execute this command
4 - make sure that /tmp/cado.j7xjqm4s/c145.renumber.gz now claims version
20220411 (first two lines)
5 - restart cado-nfs.py
(alternatively, you can change the 'd' on line 47 do decimal, and bump
the version number to the magic above above. The rest of the file should
be unchanged)
E.
On Wed, Apr 13, 2022 at 11:34:08PM -0700, Thomas D. Dean wrote:
> On 4/13/22 23:24, Emmanuel Thomé wrote:
> > Can you send me the first ~50 lines or so of the file
> > /tmp/cado.j7xjqm4s/c145.renumber.gz (dezipped, of course).
> Attached is 50 lines
> Tom Dean
Pour une évaluation indépendante, transparente et rigoureuse !
Je suis à la CE de l'Inria pour y apporter ma contribution.
- [cado-nfs] Cado-nfs Failed Factoring 143 digits, Thomas D. Dean, 04/14/2022
- Re: [cado-nfs] Cado-nfs Failed Factoring 143 digits, Paul Zimmermann, 04/14/2022
- Re: [cado-nfs] Cado-nfs Failed Factoring 143 digits, Thomas D. Dean, 04/14/2022
- Re: [cado-nfs] Cado-nfs Failed Factoring 143 digits, Emmanuel Thomé, 04/14/2022
- Re: [cado-nfs] Cado-nfs Failed Factoring 143 digits, Emmanuel Thomé, 04/15/2022
- Re: [cado-nfs] Cado-nfs Failed Factoring 143 digits, Thomas D. Dean, 04/15/2022
- Re: [cado-nfs] Cado-nfs Failed Factoring 143 digits, Thomas D. Dean, 04/16/2022
- Re: [cado-nfs] Cado-nfs Failed Factoring 143 digits, Thomas D. Dean, 04/17/2022
- Re: [cado-nfs] Cado-nfs Failed Factoring 143 digits, Paul Zimmermann, 04/17/2022
- Re: [cado-nfs] Cado-nfs Failed Factoring 143 digits, Paul Zimmermann, 04/18/2022
- Re: [cado-nfs] Cado-nfs Failed Factoring 143 digits, Thomas D. Dean, 04/18/2022
