cado-nfs - Re: [cado-nfs] cado-nfs.py factoring RSA-110 OK in 15:31min on AMD 7600X Ubuntu, fails on Debian based 64bit PiOS
  • To: hermann@stamm-wilbrandt.de
  • Cc: cado-nfs@inria.fr
  • Subject: Re: [cado-nfs] cado-nfs.py factoring RSA-110 OK in 15:31min on AMD 7600X Ubuntu, fails on Debian based 64bit PiOS
  • Date: Wed, 12 Jul 2023 15:05:59 +0200
  • Authentication-results: mail2-relais-roc.national.inria.fr; dkim=none (message not signed) header.i=none; spf=SoftFail smtp.mailfrom=Paul.Zimmermann@inria.fr; spf=None smtp.helo=postmaster@coriandre
Dear Hermann,
Which version of CADO-NFS are you using?
Can you reproduce the error if you run manually the following command?
/home/pi/cado-nfs/build/pi400-64/linalg/characters -poly
/tmp/cado.z59qan9o/c110.poly -purged /tmp/cado.z59qan9o/c110.purged.gz -index
/tmp/cado.z59qan9o/c110.index.gz -heavyblock
/tmp/cado.z59qan9o/c110.dense.bin -out /tmp/cado.z59qan9o/c110.kernel -ker
/tmp/cado.z59qan9o/c110.bwc/W -lpb0 25 -lpb1 26 -nchar 50 -t 4
And if you replace "-t 4" by "-t 1" (using only one thread)?
Best regards,
Paul Zimmermann
