Re: [cado-nfs] cado-nfs.py factoring RSA-110 OK in 15:31min on AMD 7600X Ubuntu, fails on Debian based 64bit PiOS
- To: hermann@stamm-wilbrandt.de
- Cc: cado-nfs@inria.fr
- Subject: Re: [cado-nfs] cado-nfs.py factoring RSA-110 OK in 15:31min on AMD 7600X Ubuntu, fails on Debian based 64bit PiOS
- Date: Mon, 17 Jul 2023 13:26:28 +0200
- Authentication-results: mail3-relais-sop.national.inria.fr; dkim=none (message not signed) header.i=none; spf=SoftFail smtp.mailfrom=Paul.Zimmermann@inria.fr; spf=None smtp.helo=postmaster@coriandre
Dear Hermann,
> Complete factorization of RSA-110 took 14:50min, while running with
> "--parameters ..." on the Pi400 /tmp data took less than a minute.
if it took less than a minute, probably the characters command was not run.
Paul
- [cado-nfs] cado-nfs.py factoring RSA-110 OK in 15:31min on AMD 7600X Ubuntu, fails on Debian based 64bit PiOS, hermann, 07/12/2023
- Re: [cado-nfs] cado-nfs.py factoring RSA-110 OK in 15:31min on AMD 7600X Ubuntu, fails on Debian based 64bit PiOS, Paul Zimmermann, 07/12/2023
- Re: [cado-nfs] cado-nfs.py factoring RSA-110 OK in 15:31min on AMD 7600X Ubuntu, fails on Debian based 64bit PiOS, hermann, 07/12/2023
- Re: [cado-nfs] cado-nfs.py factoring RSA-110 OK in 15:31min on AMD 7600X Ubuntu, fails on Debian based 64bit PiOS, hermann, 07/13/2023
- Re: [cado-nfs] cado-nfs.py factoring RSA-110 OK in 15:31min on AMD 7600X Ubuntu, fails on Debian based 64bit PiOS, Paul Zimmermann, 07/13/2023
- Re: [cado-nfs] cado-nfs.py factoring RSA-110 OK in 15:31min on AMD 7600X Ubuntu, fails on Debian based 64bit PiOS, hermann, 07/15/2023
- Re: [cado-nfs] cado-nfs.py factoring RSA-110 OK in 15:31min on AMD 7600X Ubuntu, fails on Debian based 64bit PiOS, Paul Zimmermann, 07/16/2023
- Re: [cado-nfs] cado-nfs.py factoring RSA-110 OK in 15:31min on AMD 7600X Ubuntu, fails on Debian based 64bit PiOS, hermann, 07/16/2023
- Re: [cado-nfs] cado-nfs.py factoring RSA-110 OK in 15:31min on AMD 7600X Ubuntu, fails on Debian based 64bit PiOS, Paul Zimmermann, 07/17/2023
- Re: [cado-nfs] cado-nfs.py factoring RSA-110 OK in 15:31min on AMD 7600X Ubuntu, fails on Debian based 64bit PiOS, hermann, 07/17/2023
- Re: [cado-nfs] cado-nfs.py factoring RSA-110 OK in 15:31min on AMD 7600X Ubuntu, fails on Debian based 64bit PiOS, Paul Zimmermann, 07/20/2023
- Re: [cado-nfs] cado-nfs.py factoring RSA-110 OK in 15:31min on AMD 7600X Ubuntu, fails on Debian based 64bit PiOS, hermann, 07/21/2023
- Re: [cado-nfs] cado-nfs.py factoring RSA-110 OK in 15:31min on AMD 7600X Ubuntu, fails on Debian based 64bit PiOS, Paul Zimmermann, 07/24/2023
- Re: [cado-nfs] cado-nfs.py factoring RSA-110 OK in 15:31min on AMD 7600X Ubuntu, fails on Debian based 64bit PiOS, hermann, 07/24/2023
- Re: [cado-nfs] cado-nfs.py factoring RSA-110 OK in 15:31min on AMD 7600X Ubuntu, fails on Debian based 64bit PiOS, hermann, 07/28/2023
