cado-nfs - Re: [cado-nfs] cado-nfs.py factoring RSA-110 OK in 15:31min on AMD 7600X Ubuntu, fails on Debian based 64bit PiOS
  • To: hermann@stamm-wilbrandt.de
  • Cc: cado-nfs@inria.fr
  • Subject: Re: [cado-nfs] cado-nfs.py factoring RSA-110 OK in 15:31min on AMD 7600X Ubuntu, fails on Debian based 64bit PiOS
  • Date: Mon, 24 Jul 2023 15:08:08 +0200
  • Authentication-results: mail3-relais-sop.national.inria.fr; dkim=none (message not signed) header.i=none; spf=SoftFail smtp.mailfrom=Paul.Zimmermann@inria.fr; spf=None smtp.helo=postmaster@coriandre
Dear Hermann,
> Regarding my previous email:
> Is it safe to use the method I described on 64bit PiOS until bug fix
> will be available?
> 1) run "./cado-nfs.py someNumber"
> 2) if that does not complete, determine parameters file in /tmp/cado...
> 3) repeat running "./cado-nfs.py --parameters determinedFile" until
> successful factorization completion
it is safe. If the factorization completes, you can check the factors.
Best regards,
Paul Zimmermann
