- To:
- Subject: Re: [cgal-discuss] CSG Operation implementation ?
- Date: Mon, 30 Oct 2006 21:38:57 -0500
It is possible using the nef polyhedron library which supports the boolean operators used for CSG, although it can be slow compared to dedicated visual hull techniques due to use of exact arithmetic. I tested visual hull computation with CGAL using the nef_3 example application (which can be told what to do from the command line), by giving it .off files of truncated viewing cone polyhedrons, and let it generate the intersection. It was something I did last year while testing EPVH, the polyhedral visual hull library I developed during my thesis.
JS Franco
On 30 Oct 2006, at 18:38, Wonwoo Lee wrote:
Hi.
Could I easily implement CSG operations such as
intersection, subtraction, etc with CGAL?
Actually, I'd like to implement a Shape from Silhouette
algorithm to create a visual hull from silhouette images.
- CSG Operation implementation ?, Wonwoo Lee, 10/31/2006
- Re: [cgal-discuss] CSG Operation implementation ?, Jean-Sébastien Franco, 10/31/2006
- Re: [cgal-discuss] CSG Operation implementation ?, Wonwoo Lee, 10/31/2006
- Re: [cgal-discuss] CSG Operation implementation ?, Peter Hachenberger, 10/31/2006
- RE: [cgal-discuss] CSG Operation implementation ?, Min Liu, 10/31/2006
