cgal-discuss - Re: [cgal-discuss] CSG Operation implementation ?
  • To:
  • Subject: Re: [cgal-discuss] CSG Operation implementation ?
  • Date: Tue, 31 Oct 2006 17:01:08 +0900
Thank for your reply Franco.
I know your EPVH library, but I have not tested
because I'm working on Windows platform.
I read CGAL document about nef polyhedron.
It provides what I wanted to do.
Does visual hull reconstruction take much time with many views ?
Did you measure the computation time to reconstruct
visual hull with CGAL and with EPVH ?
On Oct 31, 2006, at 11:38 AM, Jean-Sébastien Franco wrote:
It is possible using the nef polyhedron library which supports the boolean operators used for CSG, although it can be slow compared to dedicated visual hull techniques due to use of exact arithmetic. I tested visual hull computation with CGAL using the nef_3 example application (which can be told what to do from the command line), by giving it .off files of truncated viewing cone polyhedrons, and let it generate the intersection. It was something I did last year while testing EPVH, the polyhedral visual hull library I developed during my thesis.
JS Franco
On 30 Oct 2006, at 18:38, Wonwoo Lee wrote:
Hi.
Could I easily implement CSG operations such as
intersection, subtraction, etc with CGAL?
Actually, I'd like to implement a Shape from Silhouette
algorithm to create a visual hull from silhouette images.
