- To:
- Subject: Re: [cgal-discuss] CSG Operation implementation ?
- Date: Tue, 31 Oct 2006 12:41:36 -0500
On 31 Oct 2006, at 3:01, Wonwoo Lee wrote:
Thank for your reply Franco.
I know your EPVH library, but I have not tested
because I'm working on Windows platform.
I read CGAL document about nef polyhedron.
It provides what I wanted to do.
Does visual hull reconstruction take much time with many views ?
Did you measure the computation time to reconstruct
visual hull with CGAL and with EPVH ?
I didn't do rigorous sets of measurements per se.
But (correct me if I'm wrong) the time for a few views with something like 100 vertices per view silhouette is in the order of minutes in CGAL.
I had a 4-view example of a person (200 vertices per silhouette) that I had tested and it took about 6-7 minutes on my machine at the time (2.6 GHz I believe), provided I didn't have LEDA. After discussions with Peter I think it came out that LEDA would probably improve the speed by a factor of 2 or 3 compared to the speediest free arithmetic kernel I was able to use, the homogeneous kernel with Gmpz(?) if I remember right.
For that same example EPVH produces a manifold polyhedron in ~100ms. Note of course that it is an unfair comparison because CGAL and EPVH are very different tools and CGAL's nef_polyhedron covers a much broader functionality while EPVH is completely dedicated to polyhedral visual hulls for a dozen to a few hundred views. I also didn't try a broader range of measurements.
On 31 Oct 2006, at 5:05, Peter Hachenberger wrote:
Hi,
the newest CGAL version features a demo program for the visual hull
computation (visual_hull.C). You can find it in the directory
demo/Nef_3/ and is also briefly documented in the README file. Try it
with the input file mpi.vsh. This file defines the cones of three
letters and the demo programm intersects them and displays the result.
Peter
Very interesting! I have to test this.
Thanks for the info,
JS Franco
- CSG Operation implementation ?, Wonwoo Lee, 10/31/2006
- Re: [cgal-discuss] CSG Operation implementation ?, Jean-Sébastien Franco, 10/31/2006
- Re: [cgal-discuss] CSG Operation implementation ?, Wonwoo Lee, 10/31/2006
- Re: [cgal-discuss] CSG Operation implementation ?, Peter Hachenberger, 10/31/2006
- RE: [cgal-discuss] CSG Operation implementation ?, Min Liu, 10/31/2006
