- To:
- Subject: Multiple definition problem
- Date: Tue, 09 Jan 2007 00:42:20 +0100
Hi,
Well, I write here as I have a problem.
I was using CGAL-3.1 with Linux Ubuntu Hoary and everything was fine.
I upgraded to Linux Ubuntu Dapper and the compiler was not recognized for
CGAL-3.1, so I changed it for CGAL-3.2.1.
I could install it without any problem, but when I compile a project that
uses it (and that worked perfectly with CGAL-3.1), I get the following error:
.//libgeom.a(GenericObject.o): In function `CGAL::operator<<(CGAL::VRML_2_ostream&,
char const*)':GenericObject.cc:(.text+0x0): multiple definition of
`CGAL::operator<<(CGAL::VRML_2_ostream&, char const*)'
geometry_test.o:geometry_test.cc:(.text+0x0): first defined here
.//libgeom.a(GenericObject.o): In function `CGAL::operator<<(CGAL::VRML_2_ostream&, double
const&)':GenericObject.cc:(.text+0x28): multiple definition of
`CGAL::operator<<(CGAL::VRML_2_ostream&, double const&)'
geometry_test.o:geometry_test.cc:(.text+0x28): first defined here
I really don't know what is wrong, did anybody else met this kind of problem
before?
Any help would be appriciated.
Best regards,
Ambroise
- Multiple definition problem, Ambroise Krebs, 01/09/2007
- Re: Multiple definition problem, Sylvain Pion, 01/10/2007
- RE: [cgal-discuss] Re: Multiple definition problem, Krebs Ambroise, 01/10/2007
- Re: [cgal-discuss] Re: Multiple definition problem, Johannes Otepka, 01/10/2007
- Re: [cgal-discuss] Re: Multiple definition problem, Sylvain Pion, 01/10/2007
- RE: [cgal-discuss] Re: Multiple definition problem, Krebs Ambroise, 01/11/2007
