cgal-discuss - Re: Multiple definition problem
  • To: CGAL Mailinglist <>
  • Subject: Re: Multiple definition problem
  • Date: Wed, 10 Jan 2007 15:02:23 +0100
  • Organization: INRIA Sophia Antipolis, France
Hi Ambroise,
Ambroise Krebs wrote:
Hi,
Well, I write here as I have a problem.
I was using CGAL-3.1 with Linux Ubuntu Hoary and everything was fine.
I upgraded to Linux Ubuntu Dapper and the compiler was not recognized for CGAL-3.1, so I changed it for CGAL-3.2.1.
I could install it without any problem, but when I compile a project that uses it (and that worked perfectly with CGAL-3.1), I get the following error:
.//libgeom.a(GenericObject.o): In function `CGAL::operator<<(CGAL::VRML_2_ostream&, char const*)':GenericObject.cc:(.text+0x0): multiple definition of `CGAL::operator<<(CGAL::VRML_2_ostream&, char const*)'
geometry_test.o:geometry_test.cc:(.text+0x0): first defined here
.//libgeom.a(GenericObject.o): In function `CGAL::operator<<(CGAL::VRML_2_ostream&, double const&)':GenericObject.cc:(.text+0x28): multiple definition of `CGAL::operator<<(CGAL::VRML_2_ostream&, double const&)'
geometry_test.o:geometry_test.cc:(.text+0x28): first defined here
I really don't know what is wrong, did anybody else met this kind of problem before?
Any help would be appriciated.
What is libgeom.a and what is GenericObject.o ?
These do not come from CGAL, I think.
Also, note that sometimes install_cgal says a compiler is not supported,
while it actually works.
Best,
Sylvain Pion
INRIA Sophia-Antipolis
Geometrica Project
CGAL, http://cgal.org/
