- To:
- Subject: Re: [cgal-discuss] Intersect points of a Complex Polygon and a Flat Mesh
- Date: Sat, 10 Feb 2007 22:44:46 +0100
Olumide a écrit :
Mariette Yvinec wrote:
Use the line_face_circulator of Triangulation_2 for each edge of the polygon
Thanks! Your hint was made clearer by the following document (page 14)
http://www.cgal.org/Events/Liama_Beijing_2007_documents/TriangulationsInCGAL.pdf
One more thing: I'd like to read more about the computational geometry of the line_face_circulator because I need to write a bit about whichever method I use. I've been reading chapter 2 of Computational Geometry by Mark de Berg et. al., and in particular, the Bentley-Ottman algorithm. Does the line_face_circulator use an algorithm similar to the one described in section 2.3 is on "computing the Overlay of two subdivisions."
Thank you
- Olumide
no, the line face circulator simply travels along a line in the triangulation
- Intersect points of a Complex Polygon and a Flat Mesh, 50295, 02/08/2007
- Re: [cgal-discuss] Intersect points of a Complex Polygon and a Flat Mesh, Mariette Yvinec, 02/08/2007
- Re: [cgal-discuss] Intersect points of a Complex Polygon and a Flat Mesh, Olumide, 02/10/2007
- Re: [cgal-discuss] Intersect points of a Complex Polygon and a Flat Mesh, Mariette Yvinec, 02/10/2007
- Re: [cgal-discuss] Intersect points of a Complex Polygon and a Flat Mesh, Olumide, 02/11/2007
- Re: [cgal-discuss] Intersect points of a Complex Polygon and a Flat Mesh, Olumide, 02/13/2007
- Re: [cgal-discuss] Intersect points of a Complex Polygon and a Flat Mesh, Damian Sheehy, 02/14/2007
- Re: [cgal-discuss] Intersect points of a Complex Polygon and a Flat Mesh, Olumide, 02/15/2007
- Re: [cgal-discuss] Intersect points of a Complex Polygon and a Flat Mesh, Mariette Yvinec, 02/16/2007
- Re: [cgal-discuss] Intersect points of a Complex Polygon and a Flat Mesh, Olumide, 02/17/2007
- Re: [cgal-discuss] Intersect points of a Complex Polygon and a Flat Mesh, Mariette Yvinec, 02/17/2007
