- To:
- Subject: Re: [cgal-discuss] Intersect points of a Complex Polygon and a Flat Mesh
- Date: Sat, 17 Feb 2007 02:37:44 +0000
Mariette Yvinec wrote:
Once the first point has been located, the line_face_circulator of cgal is going to visit only faces traversed by the query
segment. Thus the complexity is equal to the number of intersection point found and not
to its worst case which is effectively p*m
I think now I understand what you mean. The tedious part of the line_face_circulator's task is to find triangle in which the starting point lies. The next triangle can be found by shooting a ray in the direction of the end point, and intersecting.locating that edge of the starting triangle that is shared with the next triangle path of the ray. (Care of course is taken to ensure that the length of the ray does not exceed the distance between the start and end points.)
But as you know, I am interested in those edges intersected by the line whose start and end is given, and not the triangles it traverses. If only there was a line_edge_circulator (oh well, that can be fixed). By the way, do adjacent each member triangles in a triangulation share edges? I hope so. (If not, I'll have to do something about coincident points on half edge pairs.)
One last issue. I would like to know how does the line_face_circulator finds the starting triangle (i.e. the one in which the starting point lies). Also, I'd like to know if a line_face_circulator can be informed of its starting triangle. I'm interested in doing this because as you can see from my diagram, the polygon P, is consists of a number of line segments, each one of which will perform a line_face_circulation on the triangular mesh M. And because the end point of one line segment s, is the start of the next line segment t, both segments s and t must lie in the same triangle. Thus there is no need for successive line_face_circulators to locate a starting triangle.
Thanks again listening to me ramble.
Regards,
- Olumide
- Intersect points of a Complex Polygon and a Flat Mesh, 50295, 02/08/2007
- Re: [cgal-discuss] Intersect points of a Complex Polygon and a Flat Mesh, Mariette Yvinec, 02/08/2007
- Re: [cgal-discuss] Intersect points of a Complex Polygon and a Flat Mesh, Olumide, 02/10/2007
- Re: [cgal-discuss] Intersect points of a Complex Polygon and a Flat Mesh, Mariette Yvinec, 02/10/2007
- Re: [cgal-discuss] Intersect points of a Complex Polygon and a Flat Mesh, Olumide, 02/11/2007
- Re: [cgal-discuss] Intersect points of a Complex Polygon and a Flat Mesh, Olumide, 02/13/2007
- Re: [cgal-discuss] Intersect points of a Complex Polygon and a Flat Mesh, Damian Sheehy, 02/14/2007
- Re: [cgal-discuss] Intersect points of a Complex Polygon and a Flat Mesh, Olumide, 02/15/2007
- Re: [cgal-discuss] Intersect points of a Complex Polygon and a Flat Mesh, Mariette Yvinec, 02/16/2007
- Re: [cgal-discuss] Intersect points of a Complex Polygon and a Flat Mesh, Olumide, 02/17/2007
- Re: [cgal-discuss] Intersect points of a Complex Polygon and a Flat Mesh, Mariette Yvinec, 02/17/2007
- Re: [cgal-discuss] Intersect points of a Complex Polygon and a Flat Mesh, Mariette Yvinec, 02/19/2007
- Re: [cgal-discuss] Intersect points of a Complex Polygon and a Flat Mesh, Andreas Fabri, 02/18/2007
- Re: [cgal-discuss] Intersect points of a Complex Polygon and a Flat Mesh, Mariette Yvinec, 02/14/2007
- Re: [cgal-discuss] Intersect points of a Complex Polygon and a Flat Mesh, Andreas Fabri, 02/14/2007
