cgal-discuss - Re: [cgal-discuss] Intersect points of a Complex Polygon and a Flat Mesh
  • To:
  • Subject: Re: [cgal-discuss] Intersect points of a Complex Polygon and a Flat Mesh
  • Date: Tue, 13 Feb 2007 22:26:22 +0000
Olumide wrote:
Shortly after writing that email, I realized that the 2D Arrangements package is probably what I need.
I've been reviewing the 2D Arrangements package and the 2D Intersection of Curves package.
I understand it, the 2D Arrangements package creates an arrangement of lines, to which a number of new lines may be added. The 2D Intersection of curves package on the other hand, requires a list of line segments (which is in effect an arrangement of lines), and finds all points of intersection between them. If this is so, these two packages fall short of what I would like to do. Just as recap, I am trying to find the the points of intersection of a complex, non self-intersecting polygon, P, and an irregular flat (triangular) mesh structure, M. Refer to the diagram http://i17.photobucket.com/albums/b52/videohead/PolyMeshIntersect.jpg . the output should be a new polygon, with intersection points consistently added to it i.e. not haphazardly, such that an imaginary ant (lets call him Billy) can walk round the augmented polygon by going from one vertex to the next, so that he returns to the starting vertex. (Can anyone think of a why did the ant walk round the polygon joke? :-) ...)
Here is my difficulty with the 2D Arrangements and 2D Intersection of Curves packages:
1. If the line segments of M and P are presented to either package as an arrangement, or a list of line segments, functions exist for computing the intersections of M and P. However the problem is that the computed intersections cannot be easily added to P, which is in fact a list of vertices. (If vertices are added haphazardly, the imaginary ant can make a round trip without going back and forth.)
2. I've also considered creating an arrangement of lines, or a list of segments from the M (alone), and then insert each line segment of P into the arrangement, or the segment list, then check for intersections. Adding the computed intersection point to P shouldn't be too difficult, however examining all line segments of M, as many times as there are the number of line segments of P seems rather inefficient. Worse still, every line segment of M will be tested with every other even line segment of M, though their intersection points are already known, and not required. Same happens if all line segments of P are tested with all line segments of M, as suggested above. There is no need to test for intersections between line segments of the same entity.
Does this rant betray my lack of understanding of CGAL and computational geometry? Is there another package that can do the job efficiently? Please enlighten the noob.
Thanks,
- Olumide
