cgal-discuss - Problem with building CGAL 3.2.1 - possible GMP vs MPFR dependency issue
  • To:
  • Subject: Problem with building CGAL 3.2.1 - possible GMP vs MPFR dependency issue
  • Date: Fri, 16 Feb 2007 18:42:56 +0100
Dear CGAL Users and developers!
I have a problem building the latest CGAL-3.2.1. I have attached the
install.log
I assume the problem is that on my setup GMP is detected as "supported"
and MPFR as "not supported".
Because of GMP, include/CGAL/number_type_basic.h includes
include/CGAL/Gmpz.h
Gmpz.h unconditionally includes <mpfr.h> which leads to the errors.
CGAL-3.1 built without problems.
Thank you for this library and Kind Regards,
Peter Schueller
log of ./install_cgal
called by ps on Fri Feb 16 17:22:10 CET 2007
CGAL_DIR is /var/tmp/ps/CGAL-3.2.1
This is install_cgal version 31254.
Parsing support specfiles for 3rd party libraries:
BOOST
BOOSTPROGRAMOPTIONS
X11
GMP
GMPXX
MPFR
CORE
CGALCORE
ZLIB
ZLIBMS
LEDA
LEDAWIN
LEDAMS
LEDAWINMS
QT3MT
QT3ST
QT3MSMT
QT3MSST
TAUCSSOLARISCC
TAUCSWINMKL
TAUCSWINATLAS
TAUCSGCCATLAS
TAUCSGCCATLAS2
TAUCSINTELCCATLAS
TAUCSINTELCCMUMPS
TAUCSDARWIN
TAUCSGCCMKL
TAUCSIRIXCC32
TAUCSIRIXCC64
CGAL version is 3.2.1.
basename is /usr/bin/basename.
dirname is /usr/bin/dirname.
uname is /bin/uname.
printf is /usr/bin/printf.
cat is /bin/cat.
cp is /bin/cp.
mv is /bin/mv.
rm is /bin/rm.
ln is /bin/ln.
ls is /bin/ls.
chmod is /bin/chmod.
mkdir is /bin/mkdir.
sed is /bin/sed.
tr is /usr/bin/tr.
awk is /usr/bin/awk.
tee is /usr/bin/tee.
find is /usr/bin/find.
tar is /bin/tar.
sed respects newline.
use _let_expr() for evaluating arithmetic expressions.
tput is /usr/bin/tput.
OS is x86-64_Linux-2.6.
got COMPILER from config/x86-64_Linux-2.6_g++-3.4.4.
set to <'g++@GNU@/usr/local/bin/gcc@/@'>.
Found compiler GNU 3.4.4.
g++ is /usr/local/bin/g++.
gcc is /usr/local/bin/gcc.
Compiler version test compiled.
x86-64_Linux-2.6_g++-3.4.4 has already been registered.
Choosing GNU 3.4.4 as compiler.
got CGAL_INSTALL_VERSION from config/x86-64_Linux-2.6_g++-3.4.4.
set to <'31254'>.
got BOOST_INCL_DIR from config/x86-64_Linux-2.6_g++-3.4.4.
set to <''>.
got BOOST_LIB_DIR from config/x86-64_Linux-2.6_g++-3.4.4.
set to <''>.
got BOOST_VERSION from config/x86-64_Linux-2.6_g++-3.4.4.
set to <'1.32.0'>.
got BOOST_PROGRAM_OPTIONS_INCL_DIR from config/x86-64_Linux-2.6_g++-3.4.4.
set to <''>.
got BOOST_PROGRAM_OPTIONS_LIB_DIR from config/x86-64_Linux-2.6_g++-3.4.4.
set to <''>.
got BOOST_PROGRAM_OPTIONS_VERSION from config/x86-64_Linux-2.6_g++-3.4.4.
set to <''>.
got X11_INCL_DIR from config/x86-64_Linux-2.6_g++-3.4.4.
set to <'/usr/X11R6/include'>.
got X11_LIB_DIR from config/x86-64_Linux-2.6_g++-3.4.4.
set to <'/usr/X11R6/lib'>.
got X11_VERSION from config/x86-64_Linux-2.6_g++-3.4.4.
set to <'11.0'>.
got GMP_INCL_DIR from config/x86-64_Linux-2.6_g++-3.4.4.
set to <''>.
got GMP_LIB_DIR from config/x86-64_Linux-2.6_g++-3.4.4.
set to <''>.
got GMP_VERSION from config/x86-64_Linux-2.6_g++-3.4.4.
set to <'4.1.4'>.
got GMPXX_INCL_DIR from config/x86-64_Linux-2.6_g++-3.4.4.
set to <''>.
got GMPXX_LIB_DIR from config/x86-64_Linux-2.6_g++-3.4.4.
set to <''>.
got GMPXX_VERSION from config/x86-64_Linux-2.6_g++-3.4.4.
set to <'4.1.4'>.
got MPFR_INCL_DIR from config/x86-64_Linux-2.6_g++-3.4.4.
set to <''>.
got MPFR_LIB_DIR from config/x86-64_Linux-2.6_g++-3.4.4.
set to <''>.
got MPFR_VERSION from config/x86-64_Linux-2.6_g++-3.4.4.
set to <''>.
got CORE_INCL_DIR from config/x86-64_Linux-2.6_g++-3.4.4.
set to <''>.
got CORE_LIB_DIR from config/x86-64_Linux-2.6_g++-3.4.4.
set to <''>.
got CORE_VERSION from config/x86-64_Linux-2.6_g++-3.4.4.
set to <'0'>.
got ZLIB_INCL_DIR from config/x86-64_Linux-2.6_g++-3.4.4.
set to <''>.
got ZLIB_LIB_DIR from config/x86-64_Linux-2.6_g++-3.4.4.
set to <''>.
got ZLIB_VERSION from config/x86-64_Linux-2.6_g++-3.4.4.
set to <'1.2.2'>.
got LEDA_INCL_DIR from config/x86-64_Linux-2.6_g++-3.4.4.
set to <''>.
got LEDA_LIB_DIR from config/x86-64_Linux-2.6_g++-3.4.4.
set to <''>.
got LEDA_VERSION from config/x86-64_Linux-2.6_g++-3.4.4.
set to <''>.
got LEDAWIN_INCL_DIR from config/x86-64_Linux-2.6_g++-3.4.4.
set to <''>.
got LEDAWIN_LIB_DIR from config/x86-64_Linux-2.6_g++-3.4.4.
set to <''>.
got LEDAWIN_VERSION from config/x86-64_Linux-2.6_g++-3.4.4.
set to <''>.
got QT_INCL_DIR from config/x86-64_Linux-2.6_g++-3.4.4.
set to <''>.
got QT_LIB_DIR from config/x86-64_Linux-2.6_g++-3.4.4.
set to <''>.
got QT_VERSION from config/x86-64_Linux-2.6_g++-3.4.4.
set to <''>.
got TAUCS_INCL_DIR from config/x86-64_Linux-2.6_g++-3.4.4.
set to <''>.
got TAUCS_LIB_DIR from config/x86-64_Linux-2.6_g++-3.4.4.
set to <''>.
got TAUCS_VERSION from config/x86-64_Linux-2.6_g++-3.4.4.
set to <''>.
got BOOST_SUPPORT from config/x86-64_Linux-2.6_g++-3.4.4.
set to <'y'>.
got BOOSTPROGRAMOPTIONS_SUPPORT from config/x86-64_Linux-2.6_g++-3.4.4.
set to <''>.
got X11_SUPPORT from config/x86-64_Linux-2.6_g++-3.4.4.
set to <'y'>.
got GMP_SUPPORT from config/x86-64_Linux-2.6_g++-3.4.4.
set to <'y'>.
got GMPXX_SUPPORT from config/x86-64_Linux-2.6_g++-3.4.4.
set to <'y'>.
got MPFR_SUPPORT from config/x86-64_Linux-2.6_g++-3.4.4.
set to <''>.
got CORE_SUPPORT from config/x86-64_Linux-2.6_g++-3.4.4.
set to <''>.
got CGALCORE_SUPPORT from config/x86-64_Linux-2.6_g++-3.4.4.
set to <'y'>.
got ZLIB_SUPPORT from config/x86-64_Linux-2.6_g++-3.4.4.
set to <'y'>.
got ZLIBMS_SUPPORT from config/x86-64_Linux-2.6_g++-3.4.4.
set to <''>.
got LEDA_SUPPORT from config/x86-64_Linux-2.6_g++-3.4.4.
set to <''>.
got LEDAWIN_SUPPORT from config/x86-64_Linux-2.6_g++-3.4.4.
set to <''>.
got LEDAMS_SUPPORT from config/x86-64_Linux-2.6_g++-3.4.4.
set to <''>.
got LEDAWINMS_SUPPORT from config/x86-64_Linux-2.6_g++-3.4.4.
set to <''>.
got QT3MT_SUPPORT from config/x86-64_Linux-2.6_g++-3.4.4.
set to <''>.
got QT3ST_SUPPORT from config/x86-64_Linux-2.6_g++-3.4.4.
set to <''>.
got QT3MSMT_SUPPORT from config/x86-64_Linux-2.6_g++-3.4.4.
set to <''>.
got QT3MSST_SUPPORT from config/x86-64_Linux-2.6_g++-3.4.4.
set to <''>.
got TAUCSSOLARISCC_SUPPORT from config/x86-64_Linux-2.6_g++-3.4.4.
set to <''>.
got TAUCSWINMKL_SUPPORT from config/x86-64_Linux-2.6_g++-3.4.4.
set to <''>.
got TAUCSWINATLAS_SUPPORT from config/x86-64_Linux-2.6_g++-3.4.4.
set to <''>.
got TAUCSGCCATLAS_SUPPORT from config/x86-64_Linux-2.6_g++-3.4.4.
set to <''>.
got TAUCSGCCATLAS2_SUPPORT from config/x86-64_Linux-2.6_g++-3.4.4.
set to <''>.
got TAUCSINTELCCATLAS_SUPPORT from config/x86-64_Linux-2.6_g++-3.4.4.
set to <''>.
got TAUCSINTELCCMUMPS_SUPPORT from config/x86-64_Linux-2.6_g++-3.4.4.
set to <''>.
got TAUCSDARWIN_SUPPORT from config/x86-64_Linux-2.6_g++-3.4.4.
set to <''>.
got TAUCSGCCMKL_SUPPORT from config/x86-64_Linux-2.6_g++-3.4.4.
set to <''>.
got TAUCSIRIXCC32_SUPPORT from config/x86-64_Linux-2.6_g++-3.4.4.
set to <''>.
got TAUCSIRIXCC64_SUPPORT from config/x86-64_Linux-2.6_g++-3.4.4.
set to <''>.
got CUSTOM_CXXFLAGS from config/x86-64_Linux-2.6_g++-3.4.4.
set to <''>.
got CUSTOM_LDFLAGS from config/x86-64_Linux-2.6_g++-3.4.4.
set to <''>.
got LONG_NAME_PROBLEM from config/x86-64_Linux-2.6_g++-3.4.4.
set to <''>.
got ENABLE_SHARED from config/x86-64_Linux-2.6_g++-3.4.4.
set to <'y'>.
WARNING: cannot find field CORE_INSTALLATION in file x86-64_Linux-2.6_g++-3.4.4.
remark: makefile_x86-64_Linux-2.6_g++-3.4.4 already exists,
 saving as .bak.
Compilation of libCGAL static x86-64_Linux-2.6_g++-3.4.4 failed.
vvvvvvvvvvvv error messages below vvvvvvvvvvvv
/usr/local/bin/g++  -O2 -Wall  '-I/var/tmp/ps/CGAL-3.2.1/include/CGAL/config/x86-64_Linux-2.6_g++-3.4.4' '-I/var/tmp/ps/CGAL-3.2.1/include'  -I/usr/X11R6/include          -DCGAL_USE_CGAL_CORE   -c assertions.cpp
/usr/local/bin/g++  -O2 -Wall  '-I/var/tmp/ps/CGAL-3.2.1/include/CGAL/config/x86-64_Linux-2.6_g++-3.4.4' '-I/var/tmp/ps/CGAL-3.2.1/include'  -I/usr/X11R6/include          -DCGAL_USE_CGAL_CORE   -c Bbox_2_intersections.cpp
In file included from /var/tmp/ps/CGAL-3.2.1/include/CGAL/number_type_basic.h:88,
                 from /var/tmp/ps/CGAL-3.2.1/include/CGAL/basic.h:35,
                 from /var/tmp/ps/CGAL-3.2.1/include/CGAL/Cartesian/Cartesian_base.h:29,
                 from /var/tmp/ps/CGAL-3.2.1/include/CGAL/Simple_cartesian.h:27,
                 from Bbox_2_intersections.cpp:25:
/var/tmp/ps/CGAL-3.2.1/include/CGAL/Gmpz.h:41:18: mpfr.h: No such file or directory
/var/tmp/ps/CGAL-3.2.1/include/CGAL/Gmpz.h: In function `std::pair<double, double> CGAL::to_interval(const CGAL::Gmpz&)':
/var/tmp/ps/CGAL-3.2.1/include/CGAL/Gmpz.h:551: error: `mpfr_t' undeclared (first use this function)
/var/tmp/ps/CGAL-3.2.1/include/CGAL/Gmpz.h:551: error: (Each undeclared identifier is reported only once for each function it appears in.)
/var/tmp/ps/CGAL-3.2.1/include/CGAL/Gmpz.h:551: error: expected `;' before "x"
/var/tmp/ps/CGAL-3.2.1/include/CGAL/Gmpz.h:552: error: `x' undeclared (first use this function)
/var/tmp/ps/CGAL-3.2.1/include/CGAL/Gmpz.h:552: error: `mpfr_init2' undeclared (first use this function)
/var/tmp/ps/CGAL-3.2.1/include/CGAL/Gmpz.h:553: error: `GMP_RNDD' undeclared (first use this function)
/var/tmp/ps/CGAL-3.2.1/include/CGAL/Gmpz.h:553: error: `mpfr_set_z' undeclared (first use this function)
/var/tmp/ps/CGAL-3.2.1/include/CGAL/Gmpz.h:554: error: `mpfr_get_d' undeclared (first use this function)
/var/tmp/ps/CGAL-3.2.1/include/CGAL/Gmpz.h:555: error: `GMP_RNDU' undeclared (first use this function)
/var/tmp/ps/CGAL-3.2.1/include/CGAL/Gmpz.h:557: error: `mpfr_clear' undeclared (first use this function)
make: *** [Bbox_2_intersections.o] Error 1
/usr/local/bin/g++  -O2 -Wall  '-I/var/tmp/ps/CGAL-3.2.1/include/CGAL/config/x86-64_Linux-2.6_g++-3.4.4' '-I/var/tmp/ps/CGAL-3.2.1/include'  -I/usr/X11R6/include          -DCGAL_USE_CGAL_CORE   -c Bbox_3_intersections.cpp
                 from Bbox_3_intersections.cpp:25:
make: *** [Bbox_3_intersections.o] Error 1
/usr/local/bin/g++  -O2 -Wall  '-I/var/tmp/ps/CGAL-3.2.1/include/CGAL/config/x86-64_Linux-2.6_g++-3.4.4' '-I/var/tmp/ps/CGAL-3.2.1/include'  -I/usr/X11R6/include          -DCGAL_USE_CGAL_CORE   -c cgal_logo.cpp
                 from cgal_logo.cpp:25:
make: *** [cgal_logo.o] Error 1
/usr/local/bin/g++  -O2 -Wall  '-I/var/tmp/ps/CGAL-3.2.1/include/CGAL/config/x86-64_Linux-2.6_g++-3.4.4' '-I/var/tmp/ps/CGAL-3.2.1/include'  -I/usr/X11R6/include          -DCGAL_USE_CGAL_CORE   -c Color.cpp
/usr/local/bin/g++  -O2 -Wall  '-I/var/tmp/ps/CGAL-3.2.1/include/CGAL/config/x86-64_Linux-2.6_g++-3.4.4' '-I/var/tmp/ps/CGAL-3.2.1/include'  -I/usr/X11R6/include          -DCGAL_USE_CGAL_CORE   -c File_header_extended_OFF.cpp
                 from /var/tmp/ps/CGAL-3.2.1/include/CGAL/IO/File_header_extended_OFF.h:28,
                 from File_header_extended_OFF.cpp:24:
make: *** [File_header_extended_OFF.o] Error 1
/usr/local/bin/g++  -O2 -Wall  '-I/var/tmp/ps/CGAL-3.2.1/include/CGAL/config/x86-64_Linux-2.6_g++-3.4.4' '-I/var/tmp/ps/CGAL-3.2.1/include'  -I/usr/X11R6/include          -DCGAL_USE_CGAL_CORE   -c File_header_OFF.cpp
                 from File_header_OFF.cpp:25:
make: *** [File_header_OFF.o] Error 1
/usr/local/bin/g++  -O2 -Wall  '-I/var/tmp/ps/CGAL-3.2.1/include/CGAL/config/x86-64_Linux-2.6_g++-3.4.4' '-I/var/tmp/ps/CGAL-3.2.1/include'  -I/usr/X11R6/include          -DCGAL_USE_CGAL_CORE   -c File_scanner_OFF.cpp
                 from File_scanner_OFF.cpp:25:
make: *** [File_scanner_OFF.o] Error 1
/usr/local/bin/g++  -O2 -Wall  '-I/var/tmp/ps/CGAL-3.2.1/include/CGAL/config/x86-64_Linux-2.6_g++-3.4.4' '-I/var/tmp/ps/CGAL-3.2.1/include'  -I/usr/X11R6/include          -DCGAL_USE_CGAL_CORE   -c File_writer_inventor.cpp
                 from /var/tmp/ps/CGAL-3.2.1/include/CGAL/IO/File_writer_inventor.h:27,
                 from File_writer_inventor.cpp:25:
make: *** [File_writer_inventor.o] Error 1
/usr/local/bin/g++  -O2 -Wall  '-I/var/tmp/ps/CGAL-3.2.1/include/CGAL/config/x86-64_Linux-2.6_g++-3.4.4' '-I/var/tmp/ps/CGAL-3.2.1/include'  -I/usr/X11R6/include          -DCGAL_USE_CGAL_CORE   -c File_writer_OFF.cpp
                 from File_writer_OFF.cpp:25:
make: *** [File_writer_OFF.o] Error 1
/usr/local/bin/g++  -O2 -Wall  '-I/var/tmp/ps/CGAL-3.2.1/include/CGAL/config/x86-64_Linux-2.6_g++-3.4.4' '-I/var/tmp/ps/CGAL-3.2.1/include'  -I/usr/X11R6/include          -DCGAL_USE_CGAL_CORE   -c File_writer_VRML_2.cpp
                 from File_writer_VRML_2.cpp:25:
make: *** [File_writer_VRML_2.o] Error 1
/usr/local/bin/g++  -O2 -Wall  '-I/var/tmp/ps/CGAL-3.2.1/include/CGAL/config/x86-64_Linux-2.6_g++-3.4.4' '-I/var/tmp/ps/CGAL-3.2.1/include'  -I/usr/X11R6/include          -DCGAL_USE_CGAL_CORE   -c File_writer_wavefront.cpp
                 from File_writer_wavefront.cpp:25:
make: *** [File_writer_wavefront.o] Error 1
/usr/local/bin/g++  -O2 -Wall  '-I/var/tmp/ps/CGAL-3.2.1/include/CGAL/config/x86-64_Linux-2.6_g++-3.4.4' '-I/var/tmp/ps/CGAL-3.2.1/include'  -I/usr/X11R6/include          -DCGAL_USE_CGAL_CORE   -c Geomview_stream.cpp
                 from Geomview_stream.cpp:24:
make: *** [Geomview_stream.o] Error 1
/usr/local/bin/g++  -O2 -Wall  '-I/var/tmp/ps/CGAL-3.2.1/include/CGAL/config/x86-64_Linux-2.6_g++-3.4.4' '-I/var/tmp/ps/CGAL-3.2.1/include'  -I/usr/X11R6/include          -DCGAL_USE_CGAL_CORE   -c Interval_arithmetic.cpp
                 from Interval_arithmetic.cpp:24:
make: *** [Interval_arithmetic.o] Error 1
/usr/local/bin/g++  -O2 -Wall  '-I/var/tmp/ps/CGAL-3.2.1/include/CGAL/config/x86-64_Linux-2.6_g++-3.4.4' '-I/var/tmp/ps/CGAL-3.2.1/include'  -I/usr/X11R6/include          -DCGAL_USE_CGAL_CORE   -c io.cpp
                 from io.cpp:28:
                 from io.cpp:28:
make: *** [io.o] Error 1
/usr/local/bin/g++  -O2 -Wall  '-I/var/tmp/ps/CGAL-3.2.1/include/CGAL/config/x86-64_Linux-2.6_g++-3.4.4' '-I/var/tmp/ps/CGAL-3.2.1/include'  -I/usr/X11R6/include          -DCGAL_USE_CGAL_CORE   -c JAMA_numeric_solver.cpp
                 from /var/tmp/ps/CGAL-3.2.1/include/CGAL/Polynomial/internal/macros.h:30,
                 from /var/tmp/ps/CGAL-3.2.1/include/CGAL/Polynomial/basic.h:41,
                 from /var/tmp/ps/CGAL-3.2.1/include/CGAL/Polynomial/internal/numeric_solvers_support.h:23,
                 from JAMA_numeric_solver.cpp:21:
In file included from /var/tmp/ps/CGAL-3.2.1/include/CGAL/Polynomial/basic.h:50,
/var/tmp/ps/CGAL-3.2.1/include/CGAL/Gmpq.h: In function `std::pair<double, double> CGAL::to_interval(const CGAL::Gmpq&)':
/var/tmp/ps/CGAL-3.2.1/include/CGAL/Gmpq.h:310: error: `mpfr_t' undeclared (first use this function)
/var/tmp/ps/CGAL-3.2.1/include/CGAL/Gmpq.h:310: error: expected `;' before "x"
/var/tmp/ps/CGAL-3.2.1/include/CGAL/Gmpq.h:311: error: `x' undeclared (first use this function)
/var/tmp/ps/CGAL-3.2.1/include/CGAL/Gmpq.h:311: error: `mpfr_init2' undeclared (first use this function)
/var/tmp/ps/CGAL-3.2.1/include/CGAL/Gmpq.h:312: error: `GMP_RNDD' undeclared (first use this function)
/var/tmp/ps/CGAL-3.2.1/include/CGAL/Gmpq.h:312: error: `mpfr_set_q' undeclared (first use this function)
/var/tmp/ps/CGAL-3.2.1/include/CGAL/Gmpq.h:313: error: `mpfr_get_d' undeclared (first use this function)
/var/tmp/ps/CGAL-3.2.1/include/CGAL/Gmpq.h:314: error: `GMP_RNDU' undeclared (first use this function)
/var/tmp/ps/CGAL-3.2.1/include/CGAL/Gmpq.h:316: error: `mpfr_clear' undeclared (first use this function)
make: *** [JAMA_numeric_solver.o] Error 1
/usr/local/bin/g++  -O2 -Wall  '-I/var/tmp/ps/CGAL-3.2.1/include/CGAL/config/x86-64_Linux-2.6_g++-3.4.4' '-I/var/tmp/ps/CGAL-3.2.1/include'  -I/usr/X11R6/include          -DCGAL_USE_CGAL_CORE   -c KDS_Log.cpp
                 from /var/tmp/ps/CGAL-3.2.1/include/CGAL/Kinetic/basic.h:35,
                 from /var/tmp/ps/CGAL-3.2.1/include/CGAL/Kinetic/internal/Log.h:23,
                 from KDS_Log.cpp:22:
In file included from /var/tmp/ps/CGAL-3.2.1/include/CGAL/Kinetic/basic.h:69,
make: *** [KDS_Log.o] Error 1
/usr/local/bin/g++  -O2 -Wall  '-I/var/tmp/ps/CGAL-3.2.1/include/CGAL/config/x86-64_Linux-2.6_g++-3.4.4' '-I/var/tmp/ps/CGAL-3.2.1/include'  -I/usr/X11R6/include          -DCGAL_USE_CGAL_CORE   -c kernel.cpp
                 from /var/tmp/ps/CGAL-3.2.1/include/CGAL/Origin.h:28,
                 from kernel.cpp:24:
                 from kernel.cpp:24:
make: *** [kernel.o] Error 1
/usr/local/bin/g++  -O2 -Wall  '-I/var/tmp/ps/CGAL-3.2.1/include/CGAL/config/x86-64_Linux-2.6_g++-3.4.4' '-I/var/tmp/ps/CGAL-3.2.1/include'  -I/usr/X11R6/include          -DCGAL_USE_CGAL_CORE   -c MP_Float.cpp
                 from /var/tmp/ps/CGAL-3.2.1/include/CGAL/MP_Float.h:27,
                 from MP_Float.cpp:24:
make: *** [MP_Float.o] Error 1
/usr/local/bin/g++  -O2 -Wall  '-I/var/tmp/ps/CGAL-3.2.1/include/CGAL/config/x86-64_Linux-2.6_g++-3.4.4' '-I/var/tmp/ps/CGAL-3.2.1/include'  -I/usr/X11R6/include          -DCGAL_USE_CGAL_CORE   -c numeric_solvers_support.cpp
                 from numeric_solvers_support.cpp:22:
make: *** [numeric_solvers_support.o] Error 1
/usr/local/bin/g++  -O2 -Wall  '-I/var/tmp/ps/CGAL-3.2.1/include/CGAL/config/x86-64_Linux-2.6_g++-3.4.4' '-I/var/tmp/ps/CGAL-3.2.1/include'  -I/usr/X11R6/include          -DCGAL_USE_CGAL_CORE   -c Polynomial.cpp
                 from /var/tmp/ps/CGAL-3.2.1/include/CGAL/Nef_2/Polynomial.h:28,
                 from Polynomial.cpp:25:
make: *** [Polynomial.o] Error 1
/usr/local/bin/g++  -O2 -Wall  '-I/var/tmp/ps/CGAL-3.2.1/include/CGAL/config/x86-64_Linux-2.6_g++-3.4.4' '-I/var/tmp/ps/CGAL-3.2.1/include'  -I/usr/X11R6/include          -DCGAL_USE_CGAL_CORE   -c Random.cpp
                 from /var/tmp/ps/CGAL-3.2.1/include/CGAL/Random.h:27,
                 from Random.cpp:24:
                 from Random.cpp:24:
make: *** [Random.o] Error 1
/usr/local/bin/g++  -O2 -Wall  '-I/var/tmp/ps/CGAL-3.2.1/include/CGAL/config/x86-64_Linux-2.6_g++-3.4.4' '-I/var/tmp/ps/CGAL-3.2.1/include'  -I/usr/X11R6/include          -DCGAL_USE_CGAL_CORE   -c Real_timer.cpp
                 from /var/tmp/ps/CGAL-3.2.1/include/CGAL/Real_timer.h:28,
                 from Real_timer.cpp:25:
make: *** [Real_timer.o] Error 1
/usr/local/bin/g++  -O2 -Wall  '-I/var/tmp/ps/CGAL-3.2.1/include/CGAL/config/x86-64_Linux-2.6_g++-3.4.4' '-I/var/tmp/ps/CGAL-3.2.1/include'  -I/usr/X11R6/include          -DCGAL_USE_CGAL_CORE   -c Timer.cpp
                 from /var/tmp/ps/CGAL-3.2.1/include/CGAL/Timer.h:28,
                 from Timer.cpp:25:
                 from Timer.cpp:25:
make: *** [Timer.o] Error 1
/usr/local/bin/g++  -O2 -Wall  '-I/var/tmp/ps/CGAL-3.2.1/include/CGAL/config/x86-64_Linux-2.6_g++-3.4.4' '-I/var/tmp/ps/CGAL-3.2.1/include'  -I/usr/X11R6/include          -DCGAL_USE_CGAL_CORE   -c Turkowski_numeric_solver.cpp
                 from Turkowski_numeric_solver.cpp:21:
make: *** [Turkowski_numeric_solver.o] Error 1
make: Target `static_lib' not remade because of errors.
^^^^^^^^^^^^ error messages above ^^^^^^^^^^^^
