Re: [cgal-discuss] Problem with building CGAL 3.2.1 - possible GMP vs MPFR dependency issue
- To:
- Subject: Re: [cgal-discuss] Problem with building CGAL 3.2.1 - possible GMP vs MPFR dependency issue
- Date: Mon, 19 Feb 2007 09:47:50 +0100
Sylvain Pion wrote:
Peter Schüller a écrit :
I have a problem building the latest CGAL-3.2.1. I have attached the
install.log
I assume the problem is that on my setup GMP is detected as "supported"
and MPFR as "not supported".
Because of GMP, include/CGAL/number_type_basic.h includes
include/CGAL/Gmpz.h
Gmpz.h unconditionally includes <mpfr.h> which leads to the errors.
Yes, if you select GMP support, you must have MPFR as well.
CGAL-3.1 built without problems.
Indeed, this is a change compared to 3.1.
The problem I have is: I did not select GMP to be built in, and I did not select MPFR to be built in.
I simply started ./install_cgal -i and it came up with autodetected settings of "GMP/GMPXX activated, MPFR deactivated".
If it is not possible to build CGAL with this setting, in my opinion the autodetection should not allow it.
But I was able to build the libraries by manually deactivating GMP/GMPXX and CORE support.
- Problem with building CGAL 3.2.1 - possible GMP vs MPFR dependency issue, Peter Schüller, 02/16/2007
- Re: [cgal-discuss] Problem with building CGAL 3.2.1 - possible GMP vs MPFR dependency issue, Sylvain Pion, 02/16/2007
- Re: [cgal-discuss] Problem with building CGAL 3.2.1 - possible GMP vs MPFR dependency issue, Peter Schüller, 02/19/2007
