- To:
- Subject: Re: [cgal-discuss] Intersect points of a Complex Polygon and a Flat Mesh
- Date: Sun, 18 Feb 2007 09:36:16 +0100
Olumide,
I sent you in a private mail the segment face iterator
that goes from a point p to a point q. Doesn't it do
the job you expect ?
andreas
Olumide wrote:
Mariette Yvinec wrote:
The line-walk has an optional parameter to set the starting face.
Great, thanks.
How about the bit about how the line_face_circulator finds:
1. the starting face when the starting face is not given,
2. triangles it traverses.
Is my explanation correct. I hate to sound like a broken record, but I need to write ab bit about my algorithm of choice in my dissertation.
Thanks,
- Olumide
- Re: [cgal-discuss] Intersect points of a Complex Polygon and a Flat Mesh, (continued)
- Re: [cgal-discuss] Intersect points of a Complex Polygon and a Flat Mesh, Olumide, 02/13/2007
- Re: [cgal-discuss] Intersect points of a Complex Polygon and a Flat Mesh, Damian Sheehy, 02/14/2007
- Re: [cgal-discuss] Intersect points of a Complex Polygon and a Flat Mesh, Olumide, 02/15/2007
- Re: [cgal-discuss] Intersect points of a Complex Polygon and a Flat Mesh, Mariette Yvinec, 02/16/2007
- Re: [cgal-discuss] Intersect points of a Complex Polygon and a Flat Mesh, Olumide, 02/17/2007
- Re: [cgal-discuss] Intersect points of a Complex Polygon and a Flat Mesh, Mariette Yvinec, 02/17/2007
- Re: [cgal-discuss] Intersect points of a Complex Polygon and a Flat Mesh, Mariette Yvinec, 02/19/2007
- Re: [cgal-discuss] Intersect points of a Complex Polygon and a Flat Mesh, Andreas Fabri, 02/18/2007
- Re: [cgal-discuss] Intersect points of a Complex Polygon and a Flat Mesh, Andreas Fabri, 02/14/2007
