cgal-discuss - Re: [cgal-discuss] Configure manual Makefile for CGAL application
  • To:
  • Subject: Re: [cgal-discuss] Configure manual Makefile for CGAL application
  • Date: Fri, 9 Mar 2007 07:27:36 -0800 (PST)
  • Domainkey-signature: a=rsa-sha1; q=dns; c=nofws; s=s1024; d=yahoo.com; h=X-YMail-OSG:Received:Date:From:Subject:To:In-Reply-To:MIME-Version:Content-Type:Content-Transfer-Encoding:Message-ID; b=wLLZwdyK6GlVkCAfEsM5ZSnm9OfxNSwPaqOOMDCF2kr+bFIb9n/QrDd2Ta4h5E8meAyjE0GUTkqj717ayofIj87dSmovEPFYJvfup9eoi/yrZdyxfHzGWmfpBwP/dkryzUaxbR/FTj7BQZe27J1hl+SHkyoklti8fdzVC7qzNIo=;
Dear Joachim:
Thanks for response. I am using pre-compiled version of CGAL
CGAL-devel-3.2.1-19.fc5
CGAL-3.2.1-19.fc5
CGAL-demos-source-3.2.1-19.fc5
running on Fedora Core 5 (Kernel 2.6.18-1.2257.fc5) with g++ (GCC) 4.1.1 20060525 (Red Hat 4.1.1-1).
I tried to compile again with the command (g++ -o test rs_example.C -I/usr/include -L/usr/lib -lCGAL
) and it showed this messages:
/usr/include/gmpxx.h: In destructor  ‘__gmp_alloc_cstring::~__gmp_alloc_cstring()’:
/usr/include/gmpxx.h:2096: error: ‘__gmp_free_func’ was not declared in this scope
I could not even use CGAL makefile.
Best regards,
Sophea
Joachim Reichel <> wrote:
Hi,
> I try to compile an example code of cgal (rs_example.C) by using my manual made Makefile.
> I am using g++.
> g++ -o test rs_example.C -I/usr/include/CGAL -L/usr/lib -lCGAL
> and it shows many erros
> /usr/include/mpfr.h:72: error: ‘mp_size_t’ does not name a type
> /usr/include/mpfr.h:77: error: ‘mp_exp_t’ does not name a type
> /usr/include/mpfr.h:78: error: expected ‘;’ before ‘*’ token
> /usr/include/mpfr.h:98: error: ‘__gmp_const’ does not name a type
> /usr/include/mpfr.h:122: error: ‘mp_exp_t’ does not name a type
> /usr/include/mpfr.h:123: error: ‘mp_exp_t’ does not name a type
> /usr/include/mpfr.h:124: error: ‘mp_exp_t’ does not name a type
"g++ rs_example.C -lCGAL" works for me. There might be a problem with
your GMP/MPFR installation.
It might be helpful if you'd provide more information, e.g. operating
system/linux distribution & version, compiler version, CGAL version,
GMP/MPFR version, whether you compiled GMP/MPFR/CGAL yourself or whether
you're using precompiled packages.
Does it work if you use the makefile provided by CGAL?
Regards,
Joachim
Now that's room service! Choose from over 150,000 hotels
in 45,000 destinations on Yahoo! Travel
to find your fit.
