- To:
- Subject: Re: [cgal-discuss] Configure manual Makefile for CGAL application
- Date: Fri, 9 Mar 2007 18:32:42 +0100
- Organization: Inria, Sophia Antipolis, FRANCE
Joachim is the packager of CGAL for Debian. I am the packager of CGAL for
Fedora. I will answer.
On Friday 09 March 2007 16:27:36 Chansophea Chuon wrote:
> I tried to compile again with the command (g++ -o test rs_example.C
> -I/usr/include -L/usr/lib -lCGAL ) and it showed this messages:
> /usr/include/gmpxx.h: In destructor
> __gmp_alloc_cstring::~__gmp_alloc_cstring(): /usr/include/gmpxx.h:2096:
> error: __gmp_free_func was not declared in this scope
> I could not even use CGAL makefile.
Here again the problem seems to come from GMP, and not CGAL.
I have not managed to reproduce your bug. I used Fedora packages, on a Fedora
Core 5.
> Thanks for response. I am using pre-compiled version of CGAL
> CGAL-devel-3.2.1-19.fc5
> CGAL-3.2.1-19.fc5
> CGAL-demos-source-3.2.1-19.fc5
CGAL-3.2.1-19.fc5
(the same)
> running on Fedora Core 5 (Kernel 2.6.18-1.2257.fc5) with g++ (GCC) 4.1.1
> 20060525 (Red Hat 4.1.1-1).
Fedora Core 5,
Kernel 2.6.17-1.2139_FC5smp,
g++ (GCC) 4.1.1 20060525 (Red Hat 4.1.1-1).
Only the kernel differs, for the moment.
What is your CPU ? Mine is "Intel(R) Pentium(R) D CPU 3.00GHz".
As for gmp :
gmp-4.1.4-6.2.1
gmp-devel-4.1.4-6.2.1
Can you give us your CPU type, and your version of GMP?
I suspect that your CPU type is not i386.
__gmp_free_func is declared in /usr/include/gmp.h
Laurent Rineau
INRIA - Sophia Antipolis
BP 93, 2004 Route des Lucioles
06902 Sophia Antipolis Cedex FRANCE
Phone: +33 4 92 38 71 54
- [cgal-discuss] Rebuild CGAL, Rubén Martínez, 03/09/2007
- Configure manual Makefile for CGAL application, Chansophea Chuon, 03/09/2007
- Re: [cgal-discuss] Configure manual Makefile for CGAL application, Joachim Reichel, 03/09/2007
- Re: [cgal-discuss] Configure manual Makefile for CGAL application, Chansophea Chuon, 03/09/2007
- Re: [cgal-discuss] Configure manual Makefile for CGAL application, Laurent Rineau, 03/09/2007
- Re: [cgal-discuss] Configure manual Makefile for CGAL application, Sylvain Pion, 03/09/2007
- Re: [cgal-discuss] Configure manual Makefile for CGAL application, Chansophea Chuon, 03/10/2007
- Re: [cgal-discuss] Configure manual Makefile for CGAL application, Andreas Fabri, 03/10/2007
