- To:
- Subject: Re: [cgal-discuss] Configure manual Makefile for CGAL application
- Date: Fri, 09 Mar 2007 21:12:00 +0100
Chansophea Chuon a écrit :
Dear Laurent:
I downloaded gmp and installed it again
gmp-devel-4.1.4-6.2.1
gmp-4.1.4-6.2.1
I try to compile the CGAL example (Point_set_2) by using the makefile from
CGAL and it produced this errors:
makefile:10: no file name for `include'
It looks like you don't have the $CGAL_MAKEFILE environment variable
defined. Maybe you only need to logout/login (the RPM adds this
variable to all users environment).
Sylvain Pion
INRIA Sophia-Antipolis
Geometrica Project
CGAL, http://cgal.org/
- [cgal-discuss] Rebuild CGAL, Rubén Martínez, 03/09/2007
- Configure manual Makefile for CGAL application, Chansophea Chuon, 03/09/2007
- Re: [cgal-discuss] Configure manual Makefile for CGAL application, Joachim Reichel, 03/09/2007
- Re: [cgal-discuss] Configure manual Makefile for CGAL application, Chansophea Chuon, 03/09/2007
- Re: [cgal-discuss] Configure manual Makefile for CGAL application, Laurent Rineau, 03/09/2007
- Re: [cgal-discuss] Configure manual Makefile for CGAL application, Sylvain Pion, 03/09/2007
- Re: [cgal-discuss] Configure manual Makefile for CGAL application, Chansophea Chuon, 03/10/2007
- Re: [cgal-discuss] Configure manual Makefile for CGAL application, Andreas Fabri, 03/10/2007
