- To:
- Subject: CGAL 3.3 Release Candidate
- Date: Fri, 25 May 2007 10:06:38 +0200
The CGAL Open Source Project is pleased to announce the release candidate
for Release 3.3 of CGAL, the Computational Geometry Algorithms Library.
You can download the tarball from
ftp://ftp.mpi-sb.mpg.de/pub/outgoing/CGAL/CGAL-3.3-RC1.tar.gz
For Windows we also provide an installer, with precompiled libraries
ftp://ftp.mpi-sb.mpg.de/pub/outgoing/CGAL/CGAL-3.3-Setup.exe
The online version of the manual can be found at
http://www.cgal.org/Manual/3.3/doc_html/cgal_manual/contents.html
We are looking forward to get your feedback and plan to release CGAL-3.3
one week from today.
Besides improvements of existing packages this release offers
the following new algorithms and data structures.
o Surface Mesh Simplification
This package provides a mesh simplification framework using edge collapse
operations, and provides the Turk/Lindstrom simplification algorithm.
o Estimation of Local Differential Properties
This package allows to compute local differential quantities of a surface
from a point sample.
o Approximation of Ridges and Umbilics on Triangulated Surface Meshes
This package enables the approximation of differential features on
triangulated surface meshes. Such curvature related features are
lines: ridges or crests, and points: umbilics.
o Envelopes of Curves in 2D
This package contains two sets of functions that construct the lower and
upper envelope diagram for a given range of bounded or unbounded curves.
o Envelopes of Surfaces in 3D
upper envelope diagram for a given range of bounded or unbounded surfaces.
The envelope diagram is realized as a 2D arrangement.
o Minkowski Sums in 2D
This package contains functions for computing planar Minkowski sums of two
closed polygons, and for a polygon and a disc (an operation also known as
offsetting or dilating a polygon).
The package also contains an efficient approximation algorithm for the
offset computation, which provides a guaranteed approximation bound while
significantly expediting the running times w.r.t. the exact computation
procedure.
o CGAL and the Boost Graph Library
This package provides the glue layer for several CGAL data structures such
that they become models of the BGL graph concept.
o Spatial Sorting
This package allows to sort points and other objects along a Hilbert curve
which can improve the performance of algorithms like triangulations.
It is used by the constructors of the triangulation package which have
an iterator range of points as argument.
o Linear and Quadratic Programming Solver
This package contains algorithms for minimizing linear and convex quadratic
functions over polyhedral domains, described by linear equations and
inequalities.
See also the Package Overview at
http://www.cgal.org/Manual/3.3/doc_html/cgal_manual/packages.html
- CGAL 3.3 Release Candidate, Andreas Meyer, 05/25/2007
- Re: [cgal-discuss] CGAL 3.3 Release Candidate, Joachim Reichel, 05/25/2007
- Re: [cgal-discuss] CGAL 3.3 Release Candidate, Laurent Rineau, 05/30/2007
- Re: [cgal-discuss] CGAL 3.3 Release Candidate, Matthijs Sypkens Smit, 05/30/2007
- Re: [cgal-discuss] CGAL 3.3 Release Candidate: failure the compile example code, Matthijs Sypkens Smit, 05/30/2007
- Re: [cgal-discuss] CGAL 3.3 Release Candidate: failure the compile example code, Andreas Fabri, 05/30/2007
