Re: [cgal-discuss] CGAL 3.3 Release Candidate: failure the compile example code
- To:
- Subject: Re: [cgal-discuss] CGAL 3.3 Release Candidate: failure the compile example code
- Date: Wed, 30 May 2007 10:52:11 +0200
Hi Matthijs,
Thank you for your feedback. These are errors we are aware of
and we think it is a compiler error. At least gcc 3.3 is the
only compiler where we observed it. So a compiler upgrade is
the recommended workaround.
best regards,
andreas
Matthijs Sypkens Smit wrote:
On Friday 25 May 2007 10:06, Andreas Meyer wrote:
We are looking forward to get your feedback and plan to release CGAL-3.3
one week from today.
All demos and examples except three compile at my workstation. The three are both the demo and example 'Surface_mesh_simplification' (same error) and the example 'BGL_polyhedron_3'. I have pasted the start of the errors:
I do not exclude the possibility that I have missed something and maybe forgot to install a dependency of perform another vital step. Can someone explain these errors or take a guess at the cause? If more error-output or information on my setup is needed I am of course happy to provide it. My system runs Debian woody.
demo/Surface_mesh_simplification:
/usr/bin/g++ -I../../include/ -I../../../BGL/include -Wall '-I/user/CGAL-3.3/include/CGAL/config/i686_Linux-2.4_g++-3.3.5' '-I/user/CGAL-3.3/include' -I/usr/X11R6/include -I/usr/include/qt3 -DCGAL_USE_F2C -DCGAL_USE_F2C -c edge_collapse_demo.cpp
In file included from ../../include/CGAL/Surface_mesh_simplification/HalfedgeGraph_Polyhedron_3.h:22,
from edge_collapse_demo.cpp:32:
../../include/CGAL/boost/graph/graph_traits_Polyhedron_3.h:146: error: specialization
of `boost::graph_traits<CGAL::Polyhedron_3<Gt, I, HDS, A> >' after
instantiation
examples/BGL_polyhedron_3:
/usr/bin/g++ -I../../include -Iinclude -Wall '-I/user/CGAL-3.3/include/CGAL/config/i686_Linux-2.4_g++-3.3.5' '-I/user/CGAL-3.3/include' -I/usr/X11R6/include -I/usr/include/qt3 -DCGAL_USE_F2C -DCGAL_USE_F2C -c kruskal.cpp
In file included from kruskal.cpp:4:
of `boost::graph_traits<CGAL::Polyhedron_3<Traits, Items, HDS, Alloc> >'
after instantiation
- CGAL 3.3 Release Candidate, Andreas Meyer, 05/25/2007
- Re: [cgal-discuss] CGAL 3.3 Release Candidate, Joachim Reichel, 05/25/2007
- Re: [cgal-discuss] CGAL 3.3 Release Candidate, Laurent Rineau, 05/30/2007
- Re: [cgal-discuss] CGAL 3.3 Release Candidate, Matthijs Sypkens Smit, 05/30/2007
- Re: [cgal-discuss] CGAL 3.3 Release Candidate: failure the compile example code, Matthijs Sypkens Smit, 05/30/2007
- Re: [cgal-discuss] CGAL 3.3 Release Candidate: failure the compile example code, Andreas Fabri, 05/30/2007
