- To:
- Subject: Re: [cgal-discuss] CGAL 3.3 Release Candidate
- Date: Wed, 30 May 2007 18:14:03 +0200
- Organization: Inria, Sophia Antipolis, FRANCE
On Friday 25 May 2007 20:28:36 Joachim Reichel wrote:
> > The CGAL Open Source Project is pleased to announce the release candidate
> > for Release 3.3 of CGAL, the Computational Geometry Algorithms Library.
> > You can download the tarball from
> > ftp://ftp.mpi-sb.mpg.de/pub/outgoing/CGAL/CGAL-3.3-RC1.tar.gz
> Debian packages for this release candidate are also available. They can
> be manually downloaded from
> http://www.joachim-reichel.de/debian/pool/non-free/c/cgal/
Fedora packages for CGAL-3.3-RC1 can be manually downloaded from
http://koji.fedoraproject.org/koji/buildinfo?buildID=7517
(select those that correspond to your arch).
They are build into Fedora devel (codename Rawhide), and are experimental
packages. They should be usable with Fedore Core 6 and Fedora 7.
Scoop: Fedora 7 is currently pushed to mirrors. The release announcement will
be published very soon. I will ask Fedora Steering Committee whether I can
build CGAL-3.3 update for Fedora 7. I may need to build a
package "compat-CGAL-3.2".
Laurent Rineau
INRIA - Sophia Antipolis
BP 93, 2004 Route des Lucioles
06902 Sophia Antipolis Cedex FRANCE
- CGAL 3.3 Release Candidate, Andreas Meyer, 05/25/2007
- Re: [cgal-discuss] CGAL 3.3 Release Candidate, Joachim Reichel, 05/25/2007
- Re: [cgal-discuss] CGAL 3.3 Release Candidate, Laurent Rineau, 05/30/2007
- Re: [cgal-discuss] CGAL 3.3 Release Candidate, Matthijs Sypkens Smit, 05/30/2007
- Re: [cgal-discuss] CGAL 3.3 Release Candidate: failure the compile example code, Matthijs Sypkens Smit, 05/30/2007
- Re: [cgal-discuss] CGAL 3.3 Release Candidate: failure the compile example code, Andreas Fabri, 05/30/2007
