cgal-discuss - Use of Vertex_handle
  • To:
  • Subject: Use of Vertex_handle
  • Date: Mon, 4 Jun 2007 08:44:25 +0200
Hello,
I have a problem trying to use a Vertex_handle: I want to navigate the
vertices of a polyhedron so I use a Halfedge_handle and I keep a std::map of
every vertex I visit, e.g.
std::map<Polyhedron::Vertex_handle, double> mymap;
Something like
Halfedge_handle = mypolyhedron.halfedges_begin();
mymap.insert(make_pair(h->vertex(), 0.0);
h = h->next();
mymap.insert(make_pair(h->vertex(), 1.0);
etc.
The problem seems to be, the temporary Vertex_handle in the above appears to
be the same object; the map won't insert the second vertex because it thinks
it is the same as the first.
Please can someone explain how to use a Vertex_handle in this kind of
situation and secondly, can you point me to where I can find the definition
of Vertex_handle and Halfedge_handle.
Many thanks
Lyndon Hill
  • Use of Vertex_handle, emptystate, 06/04/2007
