- To: <>
- Subject: Reading a surface triangulation
- Date: Mon, 4 Jun 2007 12:08:44 +0100
Hello
everybody,
I have to import a
surface triangulation into my code and I was wondering what's the best way of
doing that.
Basically, I've got
the file in this format:
x1 y1
z1 // Begin
coordinates of points
xn yn
zn // End
1 2
3
// Point connectivity, describing the triangles of the
traigulation
2 5
6
5 1
n
What do I have to
do? Create a triangulation T and then simply outputing the content of the file
to T?
in_stream >>
T
I've read the output
of out_stream << Triangulation and it seem more or less the same.The only
difference is that there are four vertices in the connectivity part, since it's
using tethraedrons. Can I use simple triangles in 3D?
Thanks
Angelo
Tardugno
- Reading a surface triangulation, Tardugno, Angelo, 06/04/2007
- Re: [cgal-discuss] Reading a surface triangulation, Mariette Yvinec, 06/05/2007
- RE: [cgal-discuss] Reading a surface triangulation, Tardugno, Angelo, 06/05/2007
