- To:
- Subject: Re: [cgal-discuss] CGAL 3.3, streamlines demo segfaults
- Date: Mon, 4 Jun 2007 11:15:59 +0200
Hi all,
When running demo/Stream_lines_2, the action 'Generate Next' from the menu
causes a segmentation fault, when before that lines are generated and the
the field is cleared.
To be more precise, here are the steps that cause a segfault with my
installation:
- start application
- load data/vnoise.vec.cin
- Menu: Placement -> Generate
[ 'success' is printed on CLI and streamlines are shows]
- Menu: Placement -> Clear
- Menu: Placement -> Generate Next
This last action results in a segmentation fault
This is with CGAL 3.3, downloaded just morning, 4-6-2007.
Matthijs Sypkens Smit
- CGAL 3.3 Released, Computational Geometry Algorithms Library, Andreas Fabri, 06/02/2007
- Re: [cgal-discuss] CGAL 3.3, streamlines demo segfaults, Matthijs Sypkens Smit, 06/04/2007
