cgal-discuss - Re: [cgal-discuss] Reading a surface triangulation
  • To:
  • Subject: Re: [cgal-discuss] Reading a surface triangulation
  • Date: Tue, 05 Jun 2007 11:25:39 +0200
Tardugno, Angelo wrote:
Hello everybody,
I have to import a surface triangulation into my code and I was wondering what's the best way of doing that.
Basically, I've got the file in this format:
x1 y1 z1            // Begin coordinates of points
xn yn zn            // End coordinates of point
1 2 3                // Point connectivity, describing the triangles of the traigulation
2 5 6
5 1 n
What do I have to do? Create a triangulation T and then simply outputing the content of the file to T?
in_stream >> T
I've read the output of out_stream << Triangulation and it seem more or less the same.The only difference is that there are four vertices in the connectivity part, since it's using tethraedrons. Can I use simple triangles in 3D?
Thanks
Angelo Tardugno
Your file looks like an off file.
Triangulation_data_structure_2  has an (undocumented) function
called off_file_input to read off-files of surface meshes.
You might try to use/adapt it ....
