- To: <>
- Subject: RE: [cgal-discuss] Reading a surface triangulation
- Date: Tue, 5 Jun 2007 12:10:57 +0100
Actually the file is a vtk file. Anyway, I think i can
transform it into an OFF file is I have to.... From: Mariette Yvinec [mailto:] Sent: 05 June 2007 10:26 To: Subject: Re: [cgal-discuss] Reading a surface triangulation
Your file looks like an off file. Triangulation_data_structure_2 has an (undocumented) function called off_file_input to read off-files of surface meshes. You might try to use/adapt it .... |
- Reading a surface triangulation, Tardugno, Angelo, 06/04/2007
- Re: [cgal-discuss] Reading a surface triangulation, Mariette Yvinec, 06/05/2007
- RE: [cgal-discuss] Reading a surface triangulation, Tardugno, Angelo, 06/05/2007
