cgal-discuss - consistency of point collinearity test and circumcenter construction
  • To:
  • Subject: consistency of point collinearity test and circumcenter construction
  • Date: Mon, 16 Jul 2007 14:27:44 +0200
Hi,
I'm wondering about the following: I know the construction of a
circumcenter (of 4 points) is only possible when the points are not
collinear. However, when using a
Exact_predicates_inexact_constructions_kernel I encounter cases where:
- coplanar_orientation() returns COLLINEAR, but the construction does not
fail and returns a point,
- coplanar_orientation() does not return COLLINEAR, but the circumcenter
construction does end in an assertion failure.
Are both these cases to be expected? In particular the last surprised me,
since I was hoping to 'catch' the assertion failure, by testing in
advance, but now it seems that this does not generally work.
Is it just plain impossible to construct circumcenters without getting
assertion failures using my choice of kernel, or are there ways around
this (by testing beforehand)?
btw;I have tried to check that using a
Exact_predicates_exact_constructions_kernel prevents the problem from
happening, but I have little experience with this kernel as of yet. I'm
getting
CGAL error: assertion violation!
Expr: !(i>s)
File: /user/CGAL-3.3/include/CGAL/Interval_nt.h
Line: 77
Explanation: Variable used before being initialized (or CGAL bug)
but so far I cannot seem to find the cause of the problem. I do believe
that all variables involved have actually been initialized.
Matthijs Sypkens Smit
