cgal-discuss - Re: [cgal-discuss] consistency of point collinearity test and circumcenter construction
  • To:
  • Subject: Re: [cgal-discuss] consistency of point collinearity test and circumcenter construction
  • Date: Mon, 16 Jul 2007 16:46:28 +0200 (CEST)
  • Importance: Normal
Le Lun 16 juillet 2007 16:38, Matthijs Sypkens Smit a écrit :
> Thank you for the explanation. I think I will be able to work with a more
> crude test for co-planarity, that works with a threshold on the distance
> of the 4th point to the plane defined by the three other points (that of
> course must not be collinear :).
If you don't care about exactness, that's perfect.
> I'm using a 3D Delaunay Triangulation. I'm not sure what triggered exactly
> the violation. Since I was just quickly checking to see if it made any
> difference without the intention of actually switching to that kernel, I
> have not bothered to investigate it in more detail.
It would still be interesting to find out why this happened (it should
not). Could you please send the code that triggers this assertion failure?
Camille
