cgal-discuss - Re: [cgal-discuss] consistency of point collinearity test and circumcenter construction
  • To:
  • Subject: Re: [cgal-discuss] consistency of point collinearity test and circumcenter construction
  • Date: Mon, 16 Jul 2007 16:38:23 +0200
On Monday 16 July 2007 16:26,
wrote:
> Le Lun 16 juillet 2007 14:27, Matthijs Sypkens Smit a écrit :
> > Exact_predicates_inexact_constructions_kernel I encounter cases where:
> > - coplanar_orientation() returns COLLINEAR, but the construction does
> > not fail and returns a point,
> > - coplanar_orientation() does not return COLLINEAR, but the
> > circumcenter construction does end in an assertion failure.
> > Are both these cases to be expected?
> Yes they are: nothing is filtered inside the construction methods.
> > In particular the last surprised me,
> > since I was hoping to 'catch' the assertion failure, by testing in
> > advance, but now it seems that this does not generally work.
> What you test beforehand with coplanar_orientation is the "exact"
> property of collinearity. The problem is that it has, for example, no
> relation with some double becoming zero in the middle of an inexact
> construction.
Thank you for the explanation. I think I will be able to work with a more
crude test for co-planarity, that works with a threshold on the distance
of the 4th point to the plane defined by the three other points (that of
course must not be collinear :).
> > CGAL error: assertion violation!
> > Expr: !(i>s)
> > File: /user/CGAL-3.3/include/CGAL/Interval_nt.h
> > Line: 77
> > Explanation: Variable used before being initialized (or CGAL bug)
> > but so far I cannot seem to find the cause of the problem. I do
> > believe that all variables involved have actually been initialized.
> This may be the bug that we corrected recently. What exactly did trigger
> this assertion violation? Are you using the Regular Triangulation? If
> you are, the attached diff-file may help you.
I'm using a 3D Delaunay Triangulation. I'm not sure what triggered exactly
the violation. Since I was just quickly checking to see if it made any
difference without the intention of actually switching to that kernel, I
have not bothered to investigate it in more detail.
