cgal-discuss - Re: [cgal-discuss] precision Problem
  • To:
  • Subject: Re: [cgal-discuss] precision Problem
  • Date: Wed, 15 Aug 2007 11:21:37 +0200
On Wednesday 15 August 2007 11:09, Kuan wrote:
> I write it not so precise. Just some points, and build a
> delaunay_triangulation_3, in some algorithm i have to find out whether a
> point is in convex hull (crust algorithm).
I'm sorry, but your problem is not very clear to me.
CGAL by itself has the capability to do exact computations of
inside/outside tests for convex hulls. If you are experiencing problems
with the results while requiring only 5 decimals of precision in your
final answer, then you are most likely doing something fundamentally
wrong.
If you cannot explain in more detail how your problem arises, I'm afraid I
cannot help you any further.
> 2007/8/15, Matthijs Sypkens Smit
> > On Wednesday 15 August 2007 02:13, Kuan wrote:
> > > Hi all,
> > > Now i have a precision problem.
> > > I am using delaunay_triangulation_3 to find out whether a point is
> > > in convex hull.
> > > But because the problem of precision, i usually get a wrong answer.
> > > For example i generate some points on a cylinder by code, and write
> > > it into a file and read it out.
> > Did you make sure to write the points out with maximal precision?
> > > And then many of the points is defined as not in convex
> > > hull.(because the number is not so precision, you can image that?).
> > The points are not in the convex hull of what? A cyclinder-surface
> > represented by triangles?
> > You are currently subscribed to cgal-discuss.
> > To unsubscribe or access the archives, go to
> > https://lists-sop.inria.fr/wws/info/cgal-discuss
