cgal-discuss - Re: [cgal-discuss] precision Problem
  • To:
  • Subject: Re: [cgal-discuss] precision Problem
  • Date: Fri, 17 Aug 2007 12:51:31 +0100
  • Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=beta; h=received:message-id:date:from:to:subject:in-reply-to:mime-version:content-type:references; b=mk/xhv09mPyPOS7PSUhNhE1k9yfK/NFM55TVtkaC4ZlmGyF7hpfQBCLb/5KQx90LBucb4HuWxwS00ZGAfqPWcfpm92UXO7lSEkNanVegCxjbUtdJoH8Um6PRKl5sLYx3TZLWqG1nrj4mZjYd3W9MBFJ6poNxmwQpEONaus3KiPM=
Hi all,
Thank for all the help. It's solved!
best regards
Kuan
2007/8/15, Andreas Fabri <>:
Kuan,
I am not sure you understood Matthijs mail correctly.
When you write coordinates to std::cout or std::ofstream
you must increase the precision as otherwise the floating point
numbers get truncated, that is 1.2345567789 becomes 1.2345.
His next point was that when you approximate a cylinder by
a polyhedron, you might miss points which are in the difference
in case the polyhedron is inscribed the cylinder.
In 2D (say the top of the cylinder)
                      *    q   *
q is outside the polyhedron (the rectangle), but inside the
cyliner (the circle)
andreas
Kuan wrote:
> I write it not so precise. Just some points, and build a
> delaunay_triangulation_3, in some algorithm i have to find out whether a
> point is in convex hull (crust algorithm).
> 2007/8/15, Matthijs Sypkens Smit <
> <mailto:>>:
>     On Wednesday 15 August 2007 02:13, Kuan wrote:
>      > Hi all,
>      > Now i have a precision problem.
>      > I am using delaunay_triangulation_3 to find out whether a point is in
>      > convex hull.
>      > But because the problem of precision, i usually get a wrong answer.
>      > For example i generate some points on a cylinder by code, and
>     write it
>      > into a file and read it out.
>     Did you make sure to write the points out with maximal precision?
>      > And then many of the points is defined as not in convex
>     hull.(because
>      > the number is not so precision, you can image that?).
>     The points are not in the convex hull of what? A cyclinder-surface
>     represented by triangles?
>     You are currently subscribed to cgal-discuss.
>     To unsubscribe or access the archives, go to
>     https://lists-sop.inria.fr/wws/info/cgal-discuss
