- To:
- Subject: Re: [cgal-discuss] precision Problem
- Date: Wed, 15 Aug 2007 02:32:37 -0700
Kuan,
I am not sure you understood Matthijs mail correctly.
When you write coordinates to std::cout or std::ofstream
you must increase the precision as otherwise the floating point
numbers get truncated, that is 1.2345567789 becomes 1.2345.
His next point was that when you approximate a cylinder by
a polyhedron, you might miss points which are in the difference
in case the polyhedron is inscribed the cylinder.
In 2D (say the top of the cylinder)
* q *
q is outside the polyhedron (the rectangle), but inside the
cyliner (the circle)
andreas
Kuan wrote:
I write it not so precise. Just some points, and build a delaunay_triangulation_3, in some algorithm i have to find out whether a point is in convex hull (crust algorithm).
2007/8/15, Matthijs Sypkens Smit < <mailto:>>:
On Wednesday 15 August 2007 02:13, Kuan wrote:
> Hi all,
> Now i have a precision problem.
> I am using delaunay_triangulation_3 to find out whether a point is in
> convex hull.
> But because the problem of precision, i usually get a wrong answer.
> For example i generate some points on a cylinder by code, and
write it
> into a file and read it out.
Did you make sure to write the points out with maximal precision?
> And then many of the points is defined as not in convex
hull.(because
> the number is not so precision, you can image that?).
The points are not in the convex hull of what? A cyclinder-surface
represented by triangles?
- precision Problem, Kuan, 08/15/2007
- Re: [cgal-discuss] precision Problem, Matthijs Sypkens Smit, 08/15/2007
- Re: [cgal-discuss] precision Problem, Kuan, 08/15/2007
- Re: [cgal-discuss] precision Problem, Andreas Fabri, 08/15/2007
- Re: [cgal-discuss] precision Problem, Kuan, 08/17/2007
