- To:
- Subject: Re: [cgal-discuss] How to generate a random Voronoi Polygon map ?
- Date: Wed, 22 Aug 2007 11:01:27 +0200
- Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=beta; h=received:message-id:date:from:user-agent:mime-version:to:subject:references:in-reply-to:content-type:content-transfer-encoding; b=LSX6ghrbagcvO/A0h8FCbXtrU+LW/4UL48DRb3hFMF3aDDV8JIojyMTdnMAyk2bj0zt2QAg9uFBbg69r+FTfAoi7aQeKDS16MLZqpiJHA5HwM4HTVgRTJkew1F4fKvTWq2gMsSDyzUUokhhMwkV8WDRjyDPS2lvTx5FGe0OW0Vg=
Apparently, the paper uses a distribution of points that is some kind of a Poisson disc distribution, which means that all points have a minimum distance to each other. Then simply the Voronoi tessellation of these points is generated, where CGAL can definitely help you -- check chapter 25 or 33 of the manual for details.
The question that is left is how to generate such a distribution, and there are many different ways to do that, e.g. dart throwing, inserting points at the center of the largest empty circle, etc. Another very excellent (but slow) method, that generates high quality uniform distributions of points, are so-called centroidal Voronoi tessellations (CVT). These CVTs can be computerd iteratively by first computing a Voronoi tessellation of a random point set (using CGAL, for example), then moving each generator point in the center of the according Voronoi region, and repeat this procedure until the distance between generator and centroid is below a chosen threshold.
I hope this helped.
Kind regards,
Michael
ZhouBo schrieb:
Greetings,
Thanks for your reply. The paper named "Incremental Instant Radiosity for Real-Time Indirect Illumination", it showed some a example, sampled some points on circle and sphere. I thought maybe it's a question about Monte Carlo sampling, quasi or uniform. I do not know how to do this with the help from CGAL.
Thanks again.
> Date: Wed, 22 Aug 2007 10:00:08 +0200
> From:
> To:
> Hi,
> what do you mean by "subdivide these polygons equally"? That there
> exists a uniform distribution of the points, or even that the sizes of
> the polygons are equal?
> Michael
ÖйúÊ®´óÈÈÃÅÂÃÓξ°µã Á˽â¸ü¶àÐÅÏ¢£¡ <http://search.msn.com/results.aspx?q=%E4%B8%AD%E5%9B%BD%E5%8D%81%E5%A4%A7%E9%A3%8E%E6%99%AF&mkt=zh-CN&form=QBRE>
- RE: [cgal-discuss] How to generate a random Voronoi Polygon map ?, ZhouBo, 08/22/2007
- Re: [cgal-discuss] How to generate a random Voronoi Polygon map ?, Michael Balzer, 08/22/2007
- Re: [cgal-discuss] How to generate a random Voronoi Polygon map ?, Peter Schröder, 08/22/2007
- <Possible follow-up(s)>
- RE: [cgal-discuss] How to generate a random Voronoi Polygon map ?, Bo Zhou, 08/22/2007
