cgal-discuss - RE: [cgal-discuss] How to generate a random Voronoi Polygon map ?
  • To: <>
  • Subject: RE: [cgal-discuss] How to generate a random Voronoi Polygon map ?
  • Date: Wed, 22 Aug 2007 17:06:32 +0800
  • Importance: Normal
Wow ! Thanks for you pointing out the key. I had thought that maybe that's a question about Poisson distribution and tessellation.
I will read your advice carefully, then implement it by hand.
Thank you very much , Micheal.
> Date: Wed, 22 Aug 2007 11:01:27 +0200
> From:
> To:
> Subject: Re: [cgal-discuss] How to generate a random Voronoi Polygon map ?
> Apparently, the paper uses a distribution of points that is some kind of
> a Poisson disc distribution, which means that all points have a minimum
> distance to each other. Then simply the Voronoi tessellation of these
> points is generated, where CGAL can definitely help you -- check chapter
> 25 or 33 of the manual for details.
> The question that is left is how to generate such a distribution, and
> there are many different ways to do that, e.g. dart throwing, inserting
> points at the center of the largest empty circle, etc. Another very
> excellent (but slow) method, that generates high quality uniform
> distributions of points, are so-called centroidal Voronoi tessellations > (CVT). These CVTs can be computerd iteratively by first computing a
> Voronoi tessellation of a random point set (using CGAL, for example),
> then moving each generator point in the center of the according Voronoi
> region, and repeat this procedure until the distance between generator
> and centroid is below a chosen threshold.
> I hope this helped.
> Kind regards,
> Michael
通过 Windows Live Spaces 与朋友轻松共享您的生活。 立即尝试!
