- To:
- Subject: Re: [cgal-discuss] How to generate a random Voronoi Polygon map ?
- Date: Wed, 22 Aug 2007 11:26:56 +0200
- Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=beta; h=received:message-id:date:from:user-agent:mime-version:to:subject:references:in-reply-to:content-type:content-transfer-encoding; b=Ix0ShpOtEtXHeZn20cQeNFBh1aFIeD80fPLQUnjuYBoCVF+EtVGRgxXA0axXR9PaxjOkDhjhau+SB+VcJPYnCQQmSTwy1OimqNwtXLdxAA/6R9t5HfD9zC8acgQ5LjV4bs5LllgoOroVUq6J7JUWmO7C07w3WB4TXDJos7Tn7UY=
Yes, CGAL has definitely one of the fastest implementations for that purpose. But in general, the computation of a CVT is quite expensive, especially for large points sets.
Michael
Peter Schröder schrieb:
Michael Balzer wrote:
The question that is left is how to generate such a distribution, and there are many different ways to do that, e.g. dart throwing, inserting points at the center of the largest empty circle, etc. Another very excellent (but slow) method, that generates high quality uniform distributions of points, are so-called centroidal Voronoi tessellations (CVT). These CVTs can be computerd iteratively by first computing a Voronoi tessellation of a random point set (using CGAL, for example), then moving each generator point in the center of the according Voronoi region, and repeat this procedure until the distance between generator and centroid is below a chosen threshold.Thanks to the speed of CGAL this can actually be done rather rapidly (and makes for a cool interactive application). Pierre Alliez once built such a little sample program. Fun and very impressive.
peter
- RE: [cgal-discuss] How to generate a random Voronoi Polygon map ?, ZhouBo, 08/22/2007
- Re: [cgal-discuss] How to generate a random Voronoi Polygon map ?, Michael Balzer, 08/22/2007
- Re: [cgal-discuss] How to generate a random Voronoi Polygon map ?, Peter Schröder, 08/22/2007
- <Possible follow-up(s)>
- RE: [cgal-discuss] How to generate a random Voronoi Polygon map ?, Bo Zhou, 08/22/2007
