- To:
- Subject: Polygon Set Symmetric Difference gives wrong results
- Date: Sat, 25 Aug 2007 18:49:49 +0200
Hello,
CGAL symmetric difference seems to give wrong results on this input:
polygon 1: (axis aligned square)
0 0
10 0
10 10
0 10
Polygon 2: (45 degrees aligned square that touches the edges of polygon 1)
5 0
10 5
5 10
0 5
The proper symmetric difference is four triangles, but the result given by
the symmetric_difference() operation gives polygon 1 as the outer boundary,
and polygon 2 as its inner holes, as if there is an "epsilon" difference
between the vertices of polygon 2 and the edges of polygon 1. Am I doing it
wrong, or is this intentional?
Thanks in advance,
Amir Vaxman.
- Polygon Set Symmetric Difference gives wrong results, avaxman, 08/25/2007
- Re: [cgal-discuss] Polygon Set Symmetric Difference gives wrong results, Efi Fogel, 08/25/2007
