cgal-discuss - Re: [cgal-discuss] Re: Boolean operations and conversion from non-exact math
  • To:
  • Subject: Re: [cgal-discuss] Re: Boolean operations and conversion from non-exact math
  • Date: Mon, 27 Aug 2007 14:45:15 +0200
  • Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=beta; h=received:message-id:date:from:sender:to:subject:in-reply-to:mime-version:content-type:content-transfer-encoding:content-disposition:references:x-google-sender-auth; b=h2dRnOV07yTO9hlky5rvq7B4bxM8CMrKOesSAsV/YMUxlVy2n5b+UJwUU7OvkMbNhkbQkbyvDnJjyEarF10tw4cpVG1+XL+jAT4fTY/Mq/WMq7A9i1QjCvPawis7dpGxplyY95yxuPa2Vt+0zkDnG+7sGFY0a9tmdbULxr7Uxzo=
On 8/27/07, Peter Hachenberger
wrote:
> you found the main problem---the facets must be coplanar. I guess it's
> not an option for you to first convert the coordinates to exact
> coordinates and then do the rotation? That's easier than doing the
> triangulation.
The rotation is just an example, in fact. Multiplying the
transformation could be done in exact math, but the source mesh itself
could contain non-planar polygons, like i.e. a sphere primitive
represented by quads. In theory, these quads should be coplanar, but
here the rounding errors occur during the primitive construction
itself.
> BTW, why are you using the Extended_homogeneous kernel? This kernel is
> very slow. Do you need to represent halfspaces? Otherwise, you should
> use another kernel.
Just part of some experimenting, to see if it changed anything. I had
tried with a Cartesian kernel first, but then switched to Homogeneous
because of the conversion to exact points that use an integer number
type.
I am currently trying a new approach. I am implementing a number type
based on double, but with comparison operators that use certain
threshold "epsilon". The equality test then returns true if the
difference between both numbers is smaller than epsilon. I am hoping
that this will trick the operations in the Nef construction and
boolean calculation into seeing approximatly coplanar points as
coplanar. I know the result won't be exact, but this is not required
in our application, where all we aim for is visually pleasing results
regards,
Bart
