- To:
- Subject: Re: [cgal-discuss] Simple polygonal mesh (height field data)
- Date: Sat, 1 Sep 2007 12:32:13 +0200
- Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=beta; h=received:from:to:subject:date:user-agent:references:in-reply-to:mime-version:content-type:content-transfer-encoding:content-disposition:message-id:sender; b=gBEpTeixVBl+wrvfRwRoxIZ6B/NI/TF59qi1jig7Qobjck5SIGuC+EXvU5Ye82PsbXaxjKV092BdJD12u/q1SGG77d6Ws4tCb49p1AVjJNyao3GbR58jRkkGsCecb7q7qUXLuGt/OobfYxkyVzrwHHFud8xDY9lMKNMF5xmyUH0=
On Saturday 01 September 2007 09:24:32
wrote:
> I have a set of points (from height fields) which I need to grid up as a
> 3D mesh. They are sampled at regular points so will form a regular grid.
> I like the idea of being able to find neighbouring points, edges and face
> using CGAL and also the subdivision surface-mesh generation.
Note that I am not a CGAL expert, but from what I saw in the documentation
http://www.cgal.org/Manual/3.3/doc_html/cgal_manual/Surface_mesher/Chapter_main.html
is what you need.
regards,
Bart
- Simple polygonal mesh (height field data), yue . nicholas, 09/01/2007
- Re: [cgal-discuss] Simple polygonal mesh (height field data), Bart Janssens, 09/01/2007
- Re: [cgal-discuss] Simple polygonal mesh (height field data), Nicholas Yue, 09/05/2007
