- To:
- Subject: Re: [cgal-discuss] Simple polygonal mesh (height field data)
- Date: Wed, 5 Sep 2007 08:20:23 +1000
- Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=beta; h=received:message-id:date:from:to:subject:in-reply-to:mime-version:content-type:references; b=aJ3QFlEjIzJ42N5eNHW1q1QDUQxRGedUDs8RBbZhF4DvdU3FgqlMZoQ2JSnPMkdRHtlvUs3ugZGeWYhPljseDUtViZfeNDFHG9gsSeSUTxh2bbvTbDiezXF9WC4rntslicPjeK00dzCSKGjhOEPA6KRkOb4dbfGfq6xA9yFZy7Y=
On 01/09/07, Bart Janssens <> wrote:
Thanks Bart, I had a look at the documentation and it looks promising. Once I get the latest CGAL-3.3 compiling on my OSX box, I will try out the example code.
On a related note, if I have a series of points (3D) which I like to use to create a mesh ( i.e. point-by-point) what approach would you suggest? For example, I have 3 points which I want to use to construct a single triangle or I have 4 points which I want to create a single quad-polygon. Which chapter describe the above?
Regards
On Saturday 01 September 2007 09:24:32 wrote:
> I have a set of points (from height fields) which I need to grid up as a
> 3D mesh. They are sampled at regular points so will form a regular grid.
> I like the idea of being able to find neighbouring points, edges and face
> using CGAL and also the subdivision surface-mesh generation.
Note that I am not a CGAL expert, but from what I saw in the documentation
http://www.cgal.org/Manual/3.3/doc_html/cgal_manual/Surface_mesher/Chapter_main.html
is what you need.
Regards
- Simple polygonal mesh (height field data), yue . nicholas, 09/01/2007
- Re: [cgal-discuss] Simple polygonal mesh (height field data), Bart Janssens, 09/01/2007
- Re: [cgal-discuss] Simple polygonal mesh (height field data), Nicholas Yue, 09/05/2007
