- To:
- Subject: Re: [cgal-discuss] print_polygon
- Date: Thu, 06 Sep 2007 15:38:05 +0900
Hi Efi,
> p.x() and p.y() return the Cartesian /x/-coordinate and the Cartesian
> y-coordinate of a point p respectively.
> p.hx(), p.hy(), and p.hw() return the homogeneous /x/-coordinate, the
> homogeneous y-coordinate, and the homogenizing coordinate respectively. //
Thanks for reply.
As you suggested, hx()/hy() function works. But its output is hx/hw format
even on x()/y() function like -1/1, 5/4 shown below.
There is example code and result.
I would like to get x/y coordinate with integer or double type variable.
Let me know any suggestion.
=== Example Code ===
#include "bso_rational_nt.h"
#include <CGAL/Cartesian.h>
#include <CGAL/Boolean_set_operations_2.h>
struct Kernel : public CGAL::Cartesian<Number_type> {};
typedef Kernel::Point_2 Point_2;
int main ()
Point_2 A(-1, 1.25);
std::cout << "A = (" << A.hx() << ":" << A.hy() << ")" << std::endl;
return 0;
== Result ==
A = (-1/1:5/4)
Kenji
- print_polygon, programer, 09/02/2007
- Re: [cgal-discuss] print_polygon, Efi Fogel, 09/02/2007
- Re: [cgal-discuss] print_polygon, K.M, 09/06/2007
- Re: [cgal-discuss] print_polygon, Martin Baeker, 09/06/2007
