- To:
- Subject: Re: [cgal-discuss] print_polygon
- Date: Thu, 06 Sep 2007 16:43:06 +0900
Hi Martin,
Thanks for quick reply. to_double() works fine.
Kenji
> The function
> CGAL::to_double()
> converts CGAL exact number types to doubles.
> Martin.
> > Hi Efi,
> > > p.x() and p.y() return the Cartesian /x/-coordinate and the Cartesian
> > > y-coordinate of a point p respectively.
> > > p.hx(), p.hy(), and p.hw() return the homogeneous /x/-coordinate, the
> > > homogeneous y-coordinate, and the homogenizing coordinate respectively.
> > Thanks for reply.
> > As you suggested, hx()/hy() function works. But its output is hx/hw format
> > even on x()/y() function like -1/1, 5/4 shown below.
> > There is example code and result.
> > I would like to get x/y coordinate with integer or double type variable.
> > Let me know any suggestion.
> > === Example Code ===
> > #include "bso_rational_nt.h"
> > #include <CGAL/Cartesian.h>
> > #include <CGAL/Boolean_set_operations_2.h>
> > struct Kernel : public CGAL::Cartesian<Number_type> {};
> > typedef Kernel::Point_2 Point_2;
> > int main ()
> > Point_2 A(-1, 1.25);
> > std::cout << "A = (" << A.hx() << ":" << A.hy() << ")" << std::endl;
> > return 0;
> > == Result ==
> > A = (-1/1:5/4)
> > Kenji
- print_polygon, programer, 09/02/2007
- Re: [cgal-discuss] print_polygon, Efi Fogel, 09/02/2007
- Re: [cgal-discuss] print_polygon, K.M, 09/06/2007
- Re: [cgal-discuss] print_polygon, Martin Baeker, 09/06/2007
