- To:
- Subject: Re: [cgal-discuss] print_polygon
- Date: Thu, 6 Sep 2007 08:55:50 +0200 (CEST)
- Organization: Institut fuer Werkstoffe TU Braunschweig
The function
CGAL::to_double()
converts CGAL exact number types to doubles.
Martin.
> Hi Efi,
> > p.x() and p.y() return the Cartesian /x/-coordinate and the Cartesian
> > y-coordinate of a point p respectively.
> > p.hx(), p.hy(), and p.hw() return the homogeneous /x/-coordinate, the
> > homogeneous y-coordinate, and the homogenizing coordinate respectively. //
> Thanks for reply.
> As you suggested, hx()/hy() function works. But its output is hx/hw format
> even on x()/y() function like -1/1, 5/4 shown below.
> There is example code and result.
> I would like to get x/y coordinate with integer or double type variable.
> Let me know any suggestion.
> === Example Code ===
> #include "bso_rational_nt.h"
> #include <CGAL/Cartesian.h>
> #include <CGAL/Boolean_set_operations_2.h>
> struct Kernel : public CGAL::Cartesian<Number_type> {};
> typedef Kernel::Point_2 Point_2;
> int main ()
> Point_2 A(-1, 1.25);
> std::cout << "A = (" << A.hx() << ":" << A.hy() << ")" << std::endl;
> return 0;
> == Result ==
> A = (-1/1:5/4)
> Kenji
> You are currently subscribed to cgal-discuss.
> To unsubscribe or access the archives, go to
> https://lists-sop.inria.fr/wws/info/cgal-discuss
Priv.-Doz. Dr. Martin Bäker
Institut für Werkstoffe
Technische Universität Braunschweig
Langer Kamp 8
38106 Braunschweig
Germany
Tel.: 00-49-531-391-3073
Fax 00-49-531-391-3058
- print_polygon, programer, 09/02/2007
- Re: [cgal-discuss] print_polygon, Efi Fogel, 09/02/2007
- Re: [cgal-discuss] print_polygon, K.M, 09/06/2007
- Re: [cgal-discuss] print_polygon, Martin Baeker, 09/06/2007
