cgal-discuss - Re: [cgal-discuss] Neighbors vertices on a Polyhedron
  • To:
  • Subject: Re: [cgal-discuss] Neighbors vertices on a Polyhedron
  • Date: Tue, 18 Sep 2007 22:22:37 +0200
Laurent Le Guillou wrote:
Hello,
With CGAL, is there a way to enumerate (with an iterator
or something) the neighboors of a vertex : for instance all the
first neighboors ("order 1" neighboors), the second neighboors
(neighboor of a neighboor, "order 2" neighboors), the third
neighboors ("order 3"), and so on, but without enumerating the same
vertex twice. I am a physicist, without a very deep knowledge of
graph-related mathematics; I searched in graph-literature but did
not found any simple algorithm. I need something quite fast as I
want to select all the neighboors of a given vertex of "order" less
than a fixed k, and I need to do this for all vertices, in order
to compute local physical properties (a "local plane" and other
mechanical properties).
Thanks a lot if someone could give me a hint on how to do this
in an efficient way (I may of course walk across the whole
polyhedron data structure several times, but my polyhedrons
have tens of thousands points...).
Cheers,
Laurent
Laurent LE GUILLOU Tel +33 1 44 27 39 93
Fax +33 1 44 27 46 38
GSM +33 6 20 05 75 22
LPNHE - Université Paris 6
Bureau 412 - Tour 33 RdC
Campus de Jussieu
4 place Jussieu
75252 Paris Cedex 05
Hello,
One way to do it is with the graph algorithms of the BGL applied to the
Polyhedron.
Here comes how the code would look like. Note that it needs the attached
fixed
versions of the graph_traits for the Polyhedron. They must go in a directory
include/CGAL/boost/graph/
Note that this fixed version is there just to illustrate the case, and needs
more
testing. It will fo in the next bug-fix release.
For CGAL and the BGL see http://www.cgal.org/Pkg/BGL
Best regards,
Andreas Fabri
#include <CGAL/Cartesian.h>
#include <CGAL/Polyhedron_3.h>
#include <CGAL/IO/Polyhedron_iostream.h>
#include <CGAL/Polyhedron_items_with_id_3.h>
#include <CGAL/boost/graph/graph_traits_Polyhedron_3.h>
#include <CGAL/boost/graph/properties_Polyhedron_3.h>
#include <boost/graph/breadth_first_search.hpp>
typedef CGAL::Cartesian<double> Kernel;
typedef Kernel::Point_3 Point;
typedef CGAL::Polyhedron_3<Kernel,CGAL::Polyhedron_items_with_id_3>
Polyhedron;
typedef boost::graph_traits<Polyhedron>::vertex_descriptor vertex_descriptor;
typedef boost::graph_traits<Polyhedron>::vertex_iterator vertex_iterator;
int main() {
int i=0;
Polyhedron P;
std::cin >> P;
// associate indices to the vertices using the "id()" field of the vertex.
vertex_iterator vb, ve;
int index = 0;
// boost::tie assigns the first and second element of the std::pair
// returned by boost::vertices to the variables vit and ve
for(boost::tie(vb,ve)=boost::vertices(P); vb!=ve; ++vb ){
vertex_descriptor vd = *vb;
vd->id() = index++;
// This is the vector where the distance gets written to
std::vector<int> distance(P.size_of_vertices());
// Here we start at an arbitrary vertex
// Any other vertex could be the starting point
std::cout << "We compute distances to " << vd->point() << std::endl;
// bfs = breadth first search explores the graph
// Just as the distance_recorder there is a way to record the predecessor
of a vertex
boost::breadth_first_search(P,
vd,
visitor(boost::make_bfs_visitor(boost::record_distances(make_iterator_property_map(distance.begin(),
get(boost::vertex_index, P)),
boost::on_tree_edge()))));
// Traverse all vertices and show at what distance they are
vd = *vb;
std::cout << vd->point() << " is " << distance[vd->id()] << " hops away"
<< std::endl;
return 0;
// Copyright (c) 2007 GeometryFactory (France). All rights reserved.
// This file is part of CGAL (www.cgal.org); you can redistribute it and/or
// modify it under the terms of the GNU Lesser General Public License as
// published by the Free Software Foundation; version 2.1 of the License.
// See the file LICENSE.LGPL distributed with CGAL.
// Licensees holding a valid commercial license may use this file in
// accordance with the commercial license agreement provided with the
software.
// This file is provided AS IS with NO WARRANTY OF ANY KIND, INCLUDING THE
// WARRANTY OF DESIGN, MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE.
// $URL:
svn+ssh:///svn/cgal/trunk/BGL/include/CGAL/boost/graph/graph_traits_Polyhedron_3.h
// $Id: graph_traits_Polyhedron_3.h 37284 2007-03-19 19:36:49Z afabri $
// Author(s) : Andreas Fabri, Fernando Cacciola
#ifndef CGAL_BOOST_GRAPH_GRAPH_TRAITS_POLYHEDRON_3_H
#define CGAL_BOOST_GRAPH_GRAPH_TRAITS_POLYHEDRON_3_H
#include <CGAL/boost/graph/graph_traits_HalfedgeDS.h>
#ifndef CGAL_CFG_NO_TMPL_IN_TMPL_PARAM
# define CGAL_HDS_PARAM_ template < class Traits, class Items, class Alloc>
class HDS
#else
# define CGAL_HDS_PARAM_ class HDS
#endif
namespace boost
template<class Gt, class I, CGAL_HDS_PARAM_, class A>
typename graph_traits< CGAL::Polyhedron_3<Gt,I,HDS,A> >::vertices_size_type
num_vertices(const CGAL::Polyhedron_3<Gt,I,HDS,A>& p)
return p.size_of_vertices();
typename graph_traits< CGAL::Polyhedron_3<Gt,I,HDS,A> const>::edges_size_type
num_edges(const CGAL::Polyhedron_3<Gt,I,HDS,A>& p)
return p.size_of_halfedges() ;
typename graph_traits< CGAL::Polyhedron_3<Gt,I,HDS,A> >::degree_size_type
degree(typename graph_traits< CGAL::Polyhedron_3<Gt,I,HDS,A>
>::vertex_descriptor v, const CGAL::Polyhedron_3<Gt,I,HDS,A>&)
return v->vertex_degree() * 2 ;
out_degree(typename graph_traits< CGAL::Polyhedron_3<Gt,I,HDS,A>
return v->vertex_degree();
in_degree(typename graph_traits< CGAL::Polyhedron_3<Gt,I,HDS,A>
struct graph_traits< CGAL::Polyhedron_3<Gt,I,HDS,A> >
: CGAL::HDS_graph_traits< CGAL::Polyhedron_3<Gt,I,HDS,A> >
typename graph_traits< CGAL::Polyhedron_3<Gt,I,HDS,A> >::vertex_descriptor
source(typename graph_traits< CGAL::Polyhedron_3<Gt,I,HDS,A>
>::edge_descriptor e, const CGAL::Polyhedron_3<Gt,I,HDS,A> & )
return e->opposite()->vertex();
target(typename graph_traits< CGAL::Polyhedron_3<Gt,I,HDS,A>
return e->vertex();
inline std::pair<typename graph_traits< CGAL::Polyhedron_3<Gt,I,HDS,A>
>::vertex_iterator
,typename graph_traits< CGAL::Polyhedron_3<Gt,I,HDS,A>
>::vertex_iterator
vertices( const CGAL::Polyhedron_3<Gt,I,HDS,A>& p)
typedef typename graph_traits< CGAL::Polyhedron_3<Gt,I,HDS,A>
>::vertex_iterator Iter;
CGAL::Polyhedron_3<Gt,I,HDS,A>& ncp =
const_cast<CGAL::Polyhedron_3<Gt,I,HDS,A>&>(p);
return std::make_pair( Iter(ncp.vertices_begin()), Iter(ncp.vertices_end())
>::edge_iterator
>::edge_iterator
edges( const CGAL::Polyhedron_3<Gt,I,HDS,A>& p)
>::edge_iterator Iter;
return std::make_pair( Iter(ncp.halfedges_begin()),
Iter(ncp.halfedges_end()) );
>::in_edge_iterator
>::in_edge_iterator
in_edges( typename graph_traits< CGAL::Polyhedron_3<Gt,I,HDS,A>
>::vertex_descriptor u, const CGAL::Polyhedron_3<Gt,I,HDS,A>& g)
typename CGAL::Polyhedron_3<Gt,I,HDS,A>::Halfedge_around_vertex_circulator
ec = u->vertex_begin();
typename graph_traits< CGAL::Polyhedron_3<Gt,I,HDS,A> >::edges_size_type
in_deg = in_degree(u,g);
>::in_edge_iterator Iter;
return std::make_pair( Iter(ec), Iter(ec,in_deg) );
>::out_edge_iterator
>::out_edge_iterator
out_edges( typename graph_traits< CGAL::Polyhedron_3<Gt,I,HDS,A>
out_deg = out_degree(u,g);
>::out_edge_iterator Iter;
return std::make_pair( Iter(ec), Iter(ec,out_deg) );
} // namespace boost
#undef CGAL_HDS_
#endif // CGAL_BOOST_GRAPH_GRAPH_TRAITS_POLYHEDRON_3_H
software.
// $URL:
svn+ssh:///svn/cgal/trunk/BGL/include/CGAL/boost/graph/properties_Polyhedron_3.h
// $Id: properties_Polyhedron_3.h 40030 2007-08-24 12:57:55Z spion $
#ifndef CGAL_BOOST_GRAPH_PROPERTIES_POLYHEDRON_3_H
#define CGAL_BOOST_GRAPH_PROPERTIES_POLYHEDRON_3_H
#include <CGAL/boost/graph/properties.h>
#include <CGAL/Unique_hash_map.h>
class HDS
#else
#endif
CGAL_BEGIN_NAMESPACE
class Polyhedron_edge_weight_map : public boost::put_get_helper<double,
Polyhedron_edge_weight_map<Gt, I, HDS, A> >
private:
typedef CGAL::Polyhedron_3<Gt,I,HDS,A> Polyhedron ;
public:
typedef boost::readable_property_map_tag
category;
typedef double
value_type;
typedef double
reference;
typedef typename boost::graph_traits<Polyhedron>::edge_descriptor key_type;
Polyhedron_edge_weight_map( Polyhedron const& ) {}
reference operator[](key_type const& e) const
return CGAL::squared_distance(e->vertex()->point(),
e->opposite()->vertex()->point());
class Polyhedron_edge_is_border_map : public boost::put_get_helper<bool,
Polyhedron_edge_is_border_map<Gt, I, HDS, A> >
private:
public:
category;
typedef bool
value_type;
typedef bool
reference;
Polyhedron_edge_is_border_map( Polyhedron const& ) {}
reference operator[](key_type const& e) const { return e->is_border(); }
class Polyhedron_edge_index_map_stored : public
boost::put_get_helper<std::size_t, Polyhedron_edge_index_map_stored<Gt, I,
HDS, A> >
private:
public:
category;
typedef std::size_t
value_type;
typedef std::size_t
reference;
Polyhedron_edge_index_map_stored( Polyhedron const& ) {}
reference operator[](key_type const& e) const { return e->id(); }
class Polyhedron_edge_index_map_external : public
boost::put_get_helper<std::size_t, Polyhedron_edge_index_map_external<Gt, I,
HDS, A> >
private:
public:
category;
typedef std::size_t
value_type;
typedef std::size_t
reference;
Polyhedron_edge_index_map_external( Polyhedron const& p)
: map(
p.halfedges_begin(),p.halfedges_end(),0,std::size_t(-1),p.size_of_halfedges()
reference operator[](key_type const& e) const { return map[e]; }
private:
CGAL::Unique_hash_map<key_type,std::size_t> map ;
class Polyhedron_vertex_point_map : public boost::put_get_helper< typename
Gt::Point_3&, Polyhedron_vertex_point_map<Gt, I, HDS, A> >
private:
public:
typedef typename Gt::Point_3 Point_3 ;
typedef boost::lvalue_property_map_tag
category;
typedef Point_3
value_type;
typedef Point_3&
reference;
typedef typename boost::graph_traits<Polyhedron>::vertex_descriptor
key_type;
Polyhedron_vertex_point_map( Polyhedron& ) {}
reference operator[](key_type const& v) const { return v->point(); }
class Polyhedron_vertex_point_const_map : public boost::put_get_helper<
typename Gt::Point_3 const&
Polyhedron_vertex_point_const_map<Gt, I, HDS, A>
private:
public:
category;
typedef Point_3
value_type;
typedef Point_3 const&
reference;
key_type;
Polyhedron_vertex_point_const_map( Polyhedron const& ) {}
class Polyhedron_vertex_index_map_stored : public
boost::put_get_helper<std::size_t, Polyhedron_vertex_index_map_stored<Gt, I,
HDS, A> >
private:
public:
category;
typedef std::size_t
value_type;
typedef std::size_t
reference;
key_type;
Polyhedron_vertex_index_map_stored( Polyhedron const& ) {}
reference operator[](key_type const& v) const { return v->id(); }
class Polyhedron_vertex_index_map_external : public
boost::put_get_helper<std::size_t, Polyhedron_vertex_index_map_external<Gt,
I, HDS, A> >
private:
public:
category;
typedef std::size_t
value_type;
typedef std::size_t
reference;
key_type;
Polyhedron_vertex_index_map_external( Polyhedron const& p)
: map(
p.vertices_begin(),p.vertices_end(),0,std::size_t(-1),p.size_of_vertices() )
reference operator[](key_type const& v) const { return map[v]; }
private:
template <class Tag>
struct Polyhedron_property_map {};
template <>
struct Polyhedron_property_map<boost::edge_weight_t>
struct bind_
typedef Polyhedron_edge_weight_map<Gt,I,HDS,A> type;
typedef Polyhedron_edge_weight_map<Gt,I,HDS,A> const_type;
template <>
struct Polyhedron_property_map<boost::edge_index_t>
struct bind_
typedef Polyhedron_edge_index_map_stored<Gt,I,HDS,A> type;
typedef Polyhedron_edge_index_map_stored<Gt,I,HDS,A> const_type;
template <>
struct Polyhedron_property_map<edge_external_index_t>
struct bind_
typedef Polyhedron_edge_index_map_external<Gt,I,HDS,A> type;
typedef Polyhedron_edge_index_map_external<Gt,I,HDS,A> const_type;
template <>
struct Polyhedron_property_map<edge_is_border_t>
struct bind_
typedef Polyhedron_edge_is_border_map<Gt,I,HDS,A> type;
typedef Polyhedron_edge_is_border_map<Gt,I,HDS,A> const_type;
template <>
struct Polyhedron_property_map<vertex_point_t>
struct bind_
typedef Polyhedron_vertex_point_map <Gt,I,HDS,A> type;
typedef Polyhedron_vertex_point_const_map<Gt,I,HDS,A> const_type;
template <>
struct Polyhedron_property_map<boost::vertex_index_t>
struct bind_
typedef Polyhedron_vertex_index_map_stored<Gt,I,HDS,A> type;
typedef Polyhedron_vertex_index_map_stored<Gt,I,HDS,A> const_type;
template <>
struct Polyhedron_property_map<vertex_external_index_t>
struct bind_
typedef Polyhedron_vertex_index_map_external<Gt,I,HDS,A> type;
typedef Polyhedron_vertex_index_map_external<Gt,I,HDS,A> const_type;
CGAL_END_NAMESPACE
namespace boost
inline
CGAL::Polyhedron_edge_weight_map<Gt,I,HDS,A> get( edge_weight_t,
CGAL::Polyhedron_3<Gt,I,HDS,A> const& p)
CGAL::Polyhedron_edge_weight_map<Gt,I,HDS,A> m(p);
return m;
inline
CGAL::Polyhedron_edge_is_border_map<Gt,I,HDS,A> get( CGAL::edge_is_border_t,
CGAL::Polyhedron_edge_is_border_map<Gt,I,HDS,A> m(p);
return m;
inline
CGAL::Polyhedron_edge_index_map_stored<Gt,I,HDS,A> get( edge_index_t,
CGAL::Polyhedron_edge_index_map_stored<Gt,I,HDS,A> m(p);
return m;
inline
CGAL::Polyhedron_edge_index_map_external<Gt,I,HDS,A> get(
CGAL::edge_external_index_t, CGAL::Polyhedron_3<Gt,I,HDS,A> const& p)
CGAL::Polyhedron_edge_index_map_external<Gt,I,HDS,A> m(p);
return m;
inline
CGAL::Polyhedron_vertex_point_map<Gt,I,HDS,A> get(CGAL::vertex_point_t,
CGAL::Polyhedron_vertex_point_map<Gt,I,HDS,A> m(p);
return m;
inline
CGAL::Polyhedron_vertex_point_const_map<Gt,I,HDS,A> get(CGAL::vertex_point_t,
CGAL::Polyhedron_vertex_point_const_map<Gt,I,HDS,A> m(p);
return m;
inline
CGAL::Polyhedron_vertex_index_map_stored<Gt,I,HDS,A> get(vertex_index_t,
CGAL::Polyhedron_vertex_index_map_stored<Gt,I,HDS,A> m(p);
return m;
inline
CGAL::Polyhedron_vertex_index_map_external<Gt,I,HDS,A>
get(CGAL::vertex_external_index_t, CGAL::Polyhedron_3<Gt,I,HDS,A> const& p)
CGAL::Polyhedron_vertex_index_map_external<Gt,I,HDS,A> m(p);
return m;
template<class Gt, class I, CGAL_HDS_PARAM_, class A, class Tag>
struct property_map<CGAL::Polyhedron_3<Gt,I,HDS,A>, Tag>
typedef typename CGAL::Polyhedron_property_map<Tag>::
template bind_<Gt,I,HDS,A> map_gen;
typedef typename map_gen::type type;
typedef typename map_gen::const_type const_type;
template<class Gt, class I, CGAL_HDS_PARAM_, class A, class PropertyTag,
class Key>
inline
typename property_traits<typename
property_map<CGAL::Polyhedron_3<Gt,I,HDS,A>,PropertyTag>::type>::reference
get(PropertyTag p, CGAL::Polyhedron_3<Gt,I,HDS,A>& g, const Key& key)
return get(get(p, g), key);
class Key>
inline
property_map<CGAL::Polyhedron_3<Gt,I,HDS,A>,PropertyTag>::const_type>::reference
get(PropertyTag p, CGAL::Polyhedron_3<Gt,I,HDS,A> const& g, const Key& key)
class Key,class Value>
inline
void put(PropertyTag p, CGAL::Polyhedron_3<Gt,I,HDS,A>& g, const Key& key,
const Value& value)
typedef typename property_map<CGAL::Polyhedron_3<Gt,I,HDS,A>,
PropertyTag>::type Map;
Map pmap = get(p, g);
put(pmap, key, value);
// What are those needed for ???
struct edge_property_type<CGAL::Polyhedron_3<Gt,I,HDS,A> >
typedef edge_weight_t type;
struct vertex_property_type<CGAL::Polyhedron_3<Gt,I,HDS,A> >
typedef CGAL::vertex_point_t type;
#undef CGAL_HDS_PARAM_
#endif // CGAL_BOOST_GRAPH_PROPERTIES_POLYHEDRON_3_H
