cgal-discuss - Re: [cgal-discuss] Neighbors vertices on a Polyhedron
  • To:
  • Subject: Re: [cgal-discuss] Neighbors vertices on a Polyhedron
  • Date: Wed, 19 Sep 2007 11:36:52 +0200
  • Organization: LPNHE - Université Paris 6 Pierre et Marie Curie
Thanks a lot!
I will try your code and let you know what I got.
Cheers,
Laurent
Andreas Fabri a écrit :
> Laurent Le Guillou wrote:
>> Hello,
>> With CGAL, is there a way to enumerate (with an iterator
>> or something) the neighboors of a vertex : for instance all the
>> first neighboors ("order 1" neighboors), the second neighboors
>> (neighboor of a neighboor, "order 2" neighboors), the third
>> neighboors ("order 3"), and so on, but without enumerating the same
>> vertex twice. I am a physicist, without a very deep knowledge of
>> graph-related mathematics; I searched in graph-literature but did
>> not found any simple algorithm. I need something quite fast as I
>> want to select all the neighboors of a given vertex of "order" less
>> than a fixed k, and I need to do this for all vertices, in order
>> to compute local physical properties (a "local plane" and other
>> mechanical properties).
> Note that the code I posted does it for one vertex
> and exhaustively.
> So you have to run it for each vertex and have a
> distance recorder that stops when k is reached.
> andreas
>> Thanks a lot if someone could give me a hint on how to do this
>> in an efficient way (I may of course walk across the whole
>> polyhedron data structure several times, but my polyhedrons
>> have tens of thousands points...).
>> Cheers,
>> Laurent
>> Laurent LE GUILLOU Tel +33 1 44 27 39 93
>> Fax +33 1 44 27 46 38
>> GSM +33 6 20 05 75 22
>> Bureau 412 - Tour 33 RdC
>> Campus de Jussieu
>> 4 place Jussieu
>> 75252 Paris Cedex 05
Those who would give up essential liberty to purchase a little
temporary safety, deserve neither liberty nor safety.
-- Benjamin Franklin (1706-1790)
Campus de Jussieu
4 place Jussieu
