cgal-discuss - Re: [cgal-discuss] 2D Cartesian Kernel (toroidal)
  • To:
  • Subject: Re: [cgal-discuss] 2D Cartesian Kernel (toroidal)
  • Date: Tue, 16 Oct 2007 09:18:26 -0700
Hi Wesley,
This might not be a direct answer to your question either, but seems very related.
We have extended the CGAL Arrangement_2 package to handle arrangements on any parametric surface of 2 parameters, for example spheres. The work is still in progress, but there are already many things that work properly. The documentation is not done yet either, but we believe that the next public release of CGAL will include this new extension.
Essentially, the (new) extended arrangement is determined by 2 traits classes, namely the geometry traits and the topology traits. The geometry traits, as in the current implementation, determines the type of geometric curves that induce the arrangement. The topology, among the other, determine the surface.
We have another package called Envelope_3, which computes envelopes of 3d surfaces. It is based on the Arrangement_2 package, and the resulting envelope, sometimes called the Minimization (or Maximization) Diagram, is obtained as an arrangement instance. With the extended arrangement package we can compute envelopes of 3d surfaces on a parametric surface, for example, on a sphere.
It is well known that Voronoi diagrams can be computed using envelopes, so combine the above, and you get Voronoi diagrams on a parametric surfaces, for example on a sphere.
We have already implemented a few traits classes that enable arrangements on surfaces that are not planar. For example, we have developed a geometry traits class that handles arcs of great circles embedded on a sphere and a companion topology traits class to handle arrangements of these arcs.
A standard Voronoi diagram of points on a sphere consists of arcs of great circles. We are not far from being able to compute standard Voronoi diagrams on spheres.
The ability to compute non standard Voronoi diagrams on spheres or any other parametric surface for that matter reduces to developing appropriate geometry and topology traits classes. The Arrangement package comes with other features, such as efficient point location and ray shooting, which you also get for free, not to mention the zone-construction and sweep-line paradigm, which are inherently part of the package.
wrote:
Hi Wesley,
This is not an answer to your question, but a related remark.
We are working on extensions of 3D triangulations to the torus (periodic space in the 3 dimensions) as well as other spaces.
This should be integrated in future CGAL releases.
In fact we reuse the same CGAL kernel, but we modify the design of the 3D triangulation package. A first research report explaining the main ideas of this new design is available from there:
http://www-sop.inria.fr/geometrica/team/Monique.Teillaud/other-geometries/
Best,
Monique Teillaud
Wesley Smith wrote:
Given the kighly parametric design of CGAL, I was wondering how
trivial/nontrivial it would be to reparametrize the 2D cartesian
kernal as a toroidal space in both dimensions. The best possible
answer would be that I would only have to change the equality measure
of Point_2, but somehow I doubt it's that simple. My ultimate goal is
to implement 2D geometry constructions such as voronoi on the surface
of a sphere where the 2 axes are angles for lattitude and longitude.
Any thoughts from people who have worked in the various kernels as to
the difficulty and steps required?
thanks,
wes
____ _ ____ _
/_____/_) o /__________ __ //
(____ ( ( ( (_/ (_/-(-'_(/
_/
